1982 F100
Old Jan 11, 2017 | 12:20 AM
97_7.3L's Avatar
97_7.3L
1982 F100
Hey all,
New to the FTE site.. But I have a question. I am a student, working on a project. Now, the State of Hawaii Dept. of Education has an old F100 carbureted 300 CID. It has a 4 speed manual, the clutch is gone. To make the truck move is a pita stalling is quite frequent. Timing and idle is set good, only got 60,000 mi. Can the rear end gearing be too high? or is the clutch that bad? Is it an issue in those years? And yes I can drive manual quite proficiently.
Thanks,
Jack
Old Jan 11, 2017 | 07:40 AM
Gary Lewis's Avatar
Gary Lewis
I would think that killing the 300 because the clutch is bad would be difficult to do. That engine has excellent torque at low RPM when running correctly. Ford did put very tall rear axles in some of these trucks, and you would have to slip the clutch some to get them rolling. Go to my web site, link in my sig, and find the certification label decoder. (I can't get in right now to give you the link.) The look on the door post and decode the cert label to find out about the axle ratio, and other things.
Old Jan 11, 2017 | 07:45 PM
DeereFord300's Avatar
DeereFord300
Some trucks came stock with 2.47 rear gears (aka waaay too high for a pick up), especially so in F100s, so if it did stall easily I wouldn't be surprised
Old Jan 12, 2017 | 09:01 AM
1986F150six's Avatar
1986F150six
I drove a 1984 F150 with 4.9L, 4 speed manual O.D. and 2.47 rear gears for years. Yes, it is geared very high [for gas mileage], but was not prone to stalling. What do you mean by "the clutch is gone"?
Welcome to the forum!
Old Jan 12, 2017 | 10:08 AM
Ford F834's Avatar
Ford F834
I just recently acquired a 1981 F150 straight six T18 four speed manual that has 2.75 axle gears and 31x10.5 tires. Second gear starts are just fine. A little more clutch slip than I'm used to on my F250's and F350, but no stalling at all.
Old Jan 12, 2017 | 01:47 PM
97_7.3L's Avatar
97_7.3L
When I mean the clutch is gone I mean the clutch is burnt. Slipping big time
Old Jan 12, 2017 | 01:54 PM
ctubutis's Avatar
ctubutis
I guess it's conceivably possible for a broken clutch assembly to stall the engine, but I'd have a hard time believing a merely worn-out one is.
So, I guess you're not gonna really know until you replace the clutch and remove that variable from the equation, then go down the engine path if there's still a problem.
Robs89wag
General Diesel Discussion
Jan 17, 2017 07:36 PM
Jarryd
Jun 22, 2013 12:02 AM
Amphenol
Aug 11, 2011 02:23 PM
raycgl
Nov 16, 2008 01:14 PM
Red77F100
May 5, 2006 02:10 PM
