It has a know weak pump. You don't have dummy plugs or standpipes with the log type oil rail. That leaves the pump or nipple cups and injector seals. Save your $$$, your going to be buying a pump soon. Get the Adrenaline pump.
Don't gamble with the OEM reman. It's the only thing most will tell you is not worth it. Injectors? yes, absolutely OEM remans only.
HPOP, not so much.
I would be sure you CONFIRM with the company you will be getting the CORRECT o-rings with it if you go Adrenaline. That or just buy the OEM o-rings, there have been issues lately with the o-rings they are sending with the pumps.
the adrenaline sounds like what ill get, ive heard a lot of good things about it and most people do recommend it id rather spend the money and not go back into this thing for a while
And I'd at least air test the system before condemning the pump. Hook up the air fitting to the ICP Port and listen to the oil filter housing with the cap removed... gurgling or any air noises, it's going south.
Did you command the IPR closed? Without the IPR in the correct position, it will route the air into the oil reservoir and sound like a bad pump.
If you do the air test through the IPR port, then it won't need to be closed. If you did the test using the ICP port, it will need closed. Apply 12v to the IPR for short periods while applying air to the ICP port.
i got the adrenaline hpop, old one was bad but i still have a random miss, low boost max of 17psi, but now i am throwing a cope for injection control pressure circuit low, which is my icp but it is new, can this code cause these problems
ICP is new but is the pigtail new?
Was the old ICP oily?
Pretty common on these for the ICP to burp oil all over creation and crawl up the pigtail harness. That will cause problems with an oily plug/harness even with a new ICP sensor
What I'm thinking as well. Also clean the MAP, EBP sensors and tubes, check for cracks in the rubber and clean the nipple. If your EGR is in tact, clean that sensor as well... you should be able to hit 28lbs of boost... it's a combination of those sensors that make the boost numbers.
17psi and no codes?
Check all the rubber CAC boots, specifically where they have the metal wire reinforcement, where the clamp goes and if you have the plastic tube.... discharge side.
You cleaned MAP, EBP, IAT/EGR and the tube/hose that feed them with trimmer line? What is MAP/BARO/EBP before you crank up? They should be near 14.7?
ive done all that, the cac boots are new not even 4 months old, ive pulled the intercooler and checked for leaks, all my sensors read as the should, i cant check ebp so not sure about that one, i know its not my head gaskets and ive done everything you can think of the this thing, my last thought is i have a cylinder with bad compression but it idles great and smooth except the random miss, even at idle when the turbo cycles its very quite, the ficm is 58v sinister diesel which isnt a year old, no exhaust leaks
