Sponsored by: Real Truck
Codes. Help please
Old Jan 10, 2017 | 04:29 PM
Mpollard1990's Avatar
Mpollard1990
Codes. Help please
1999 f250 with 5.4. Put new head gaskets on it and got it back running. So far I have put new bank one sensor one 02 sensor and new mass air flow. Truck runs good then bogs for a second and straightens up. Current codes are p1142. P0135 and p1151
Old Jan 13, 2017 | 03:33 PM
D.Yaros's Avatar
D.Yaros
P0135 Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
Read more at: https://www.obd-codes.com/p0135
P1142 - (Ford) Powertrain-Fuel and Air Metering Description: Fuel Restriction Condition
P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
Read more at: https://www.obd-codes.com/trouble_codes/ford/
Old Jan 13, 2017 | 08:40 PM
Mpollard1990
Any idea what might cause all these?
Old Jan 13, 2017 | 10:47 PM
erikc838's Avatar
erikc838
Mine was giving me the same code but for the other bank (minus the fuel restriction one). I replaced the upstream sensor (actually both) and the problem went away.
PS, those sensors are a lot cheaper on Amazon than your local parts store. I got 2 of the same part, for less than 1 and free shipping.
Old Jan 15, 2017 | 02:45 PM
D.Yaros's Avatar
D.Yaros
I cannot help on the cause. Did what I could to help you by finding out what the codes mean/indicate.
Old Jan 16, 2017 | 01:16 PM
Mike1's Avatar
Mike1
I had the same codes going on my 04 CTS, come to find out where the header pipe and the exhaust pipe met, the gasket was oh so slightly leaking, just enough I guess to suck in air and cause a lean condition.
Old Jan 16, 2017 | 01:58 PM
Mpollard1990
Thanks for all the help. I'm still trying to figure it out
Pmax
Mar 28, 2018 02:59 PM
Mpollard1990
Modular V8 (4.6L, 5.4L)
Jan 12, 2017 01:17 AM
CPerry
1997 - 2003 F150
Oct 6, 2010 06:39 PM
Crazy1965
Feb 14, 2007 09:47 PM
rook64
Mar 31, 2003 04:25 PM
