fuel filter restriction sensor
Old Jan 10, 2017 | 03:12 PM
benharpo's Avatar
benharpo
Hi,
I've got a leaky fuel bowl on a 1998 E-350 with 7.3L powerstroke turbo engine. I think they used two different fuel filter styles that year, mine is the type with the threaded plastic cap on the filter.
In the center of my photo is the part that drips. It is a brass **** about the size of a quarter near the top on the left side of the fuel bowl. Actually it hangs off the assembly that contains the water separator and fuel heater. It has a 90 degree boot with a wire on it.
I believe this part is called the fuel filter restriction sensor, or fuel filter vacuum switch.
From what I've read on various forums it seems like some people just remove it and install a brass plug.
I would appreciate any help before I take anything apart. If it requires removing the fuel bowl, etc, I will probably take it to a professional. If I can pry off the wire boot, unthread the sensor, and thread in a plug, then I will probably do it myself.
Also, what diameter and thread pitch of a plug do i need to get?
Old Jan 10, 2017 | 03:39 PM
annaleigh's Avatar
annaleigh
have you read this thread?
https://www.ford-trucks.com/forums/9...on-sensor.html
What is it called?
Maybe
BRAND NEW FORD OEM FUEL FILTER VACUUM INDICATOR SWITCH #E8TZ-9S283-A
http://www.ebay.com/itm/BRAND-NEW-FORD-OEM-FUEL-FILTER-VACUUM-INDICATOR-SWITCH-E8TZ-9S283-A/281559729793?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D40791%26meid%3D2197ff4d8bbd4cb0b29283871c300bef%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D200747409363
OR
Ford 7.3 Diesel Fuel Filter Vacuum Indicator Dash Light Switch OEM E8TZ 9S283 A
http://www.ebay.com/itm/Ford-7-3-Die...tXyvNj&vxp=mtr
OR
E8TZ9S283A - SWITCH ASY FUEL FILTER VAC - Ford
http://www.ebay.com/itm/E8TZ9S283A-S...pYWbA4&vxp=mtr
Old Jan 16, 2017 | 05:14 PM
blageurt's Avatar
blageurt
don't even think about replacing that POS....Just plug it with w 1/4 NPT plug and forget it..It is a useless thing...IF you change your Fuel Filters as per factory specs...You don't need it...
Edale4
Sep 5, 2017 12:45 AM
bryanlindborg600
Oct 30, 2011 10:07 PM
bill1954
Jun 26, 2011 09:55 PM
plgebbia
Jul 28, 2010 10:07 PM
smokey352
Mar 29, 2007 08:51 PM
