Fuel Filter Change
Old Aug 29, 2003 | 02:21 PM
Ggg6's Avatar
Ggg6
Fuel Filter Change
trackman, Allways use a high quality fuel filter in these PSD's they are vrey sensative to fuel system contamination. One of the things to look for in a good furl filter are the small o-ring has a beveled edge, it is not a true o-ring. Regular o-rings will not seal properly and leak internally. Some of the better brands for the 7.3 PSD are; Motorcraft FD4595 (1994-1998) or FD4596 (1998.5 +), Donaldson, Baldwin PF7678, Racor IN F4595 or IN F4596. Myself and others have had bad experience with Fram and Wix.
Old Aug 29, 2003 | 03:46 PM
HeatStroked's Avatar
HeatStroked
Fuel Filter Change
Fisher-Man
If your filter still leaks; Be sure that you include the (2) "O" rings that come with the filter and that the outer ring is installed corectly. It is tapered.
Old Aug 31, 2003 | 04:48 PM
Mark3682's Avatar
Mark3682
Fuel Filter Change
Fisher, I bought a "DEUTSCH" filter from auto zone last week $24.99 and it comes with a new plastic cap which has a star in the middle so you can use a 3/8" drive ratch to tighten and loosen.
Old Sep 1, 2003 | 03:33 AM
Mach1's Avatar
Mach1
Fuel Filter Change
I get Racor's for $14 all day long...they make the Motorcraft and motorcraft puts their name on them..
KelVarnson
60
Aug 18, 2022 05:49 PM
tracyclifton
6.7L Power Stroke Diesel
21
Mar 30, 2016 04:45 PM
sowaxeman
Apr 15, 2015 06:50 AM
Sledgehammered
Aug 9, 2014 02:29 PM
Orpackrat
Bio-diesel, Propane & Alternative Diesel Engine Fuels
15
Sep 16, 2013 05:09 PM
