Heater Duct question
Old 01-09-2017, 08:40 PM
Joshua Christopher's Avatar
Joshua Christopher
Joshua Christopher is offline
Hello everyone,
Been lurking but this is my first post. I recently bought a 1977 F250 Custom 2WD w/ 351 and no AC. I replaced my heater core and the blower motor today. I noticed though, that the Y-shaped vent that goes up to the defrost openings doesn't connect to the actual heater box. It seems there is a short square shaped length of duct hose that goes between the Y vent and the heater box. Does anyone have an extra, or have they found something that works instead?
I am talking about part #18547 in this photo.
Old 01-09-2017, 10:03 PM
march's Avatar
march
march is offline
Josh, Are you sure you don't have a set up like this. (no connector)
Old 01-09-2017, 10:44 PM
maytea's Avatar
maytea
maytea is offline
On mine it is just a thick foam gasket
Old 01-09-2017, 11:22 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,317 Likes on 2,467 Posts
#18547 is a black plastic ribbed xylophone like (compressed to go in then expands to lock in place, set up). Probably have to hit a JY.
I do not think I have an extra, I will try to look tomorrow.
Old 01-10-2017, 04:45 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
No 18547 gasket listed the parts catalog for F100/350 after 1976.
There's only one illustration of the fresh air heater for 1973/79, but the text section doesn't list the gasket for 1977/79.
In fact, it's only listed for 1975/76 with fresh air heater: D5TZ-18547-A
Old 01-13-2017, 08:02 PM
77&79F250's Avatar
77&79F250
Checked my parts trucks/Bronco's, checked the parts shed box of spare flex tubing...nothing.
Old 10-12-2017, 09:25 PM
Aaron-71's Avatar
Aaron-71
Aaron-71 is offline
Drudging up an old thread for good purpose.
Does anyone have a picture of what the vent looks like?
Is it plastic or paper? I would assume paper as the diffuser below the heater box is paper.
Just found this post online: https://www.ford-trucks.com/forums/1...rost-duct.html
Looks a lot like paper to me, but can someone confirm?
Old 10-12-2017, 10:13 PM
77&79F250's Avatar
77&79F250
99% sure its plastic with metal staples holding to the defroster vent on the top and plastic like rivets 380457-S holding it on the bottom.
Old 10-12-2017, 10:56 PM
thatsrealnice's Avatar
thatsrealnice
thatsrealnice is offline
Why use that stuff, when you could just do this?
Old 10-12-2017, 11:45 PM
77&79F250's Avatar
77&79F250
That shizznat is priceless!
Old 10-12-2017, 11:56 PM
thatsrealnice
Saw that in a truck at the UPullandPay a couple of years ago. Guess it beats driving with no heat in the winter.
Old 10-13-2017, 12:35 AM
75BigBlock's Avatar
75BigBlock
75BigBlock is offline
Well it IS a Custom.
Old 10-13-2017, 09:54 AM
Aaron-71's Avatar
Aaron-71
Aaron-71 is offline
I also just noticed that the whale tail for the fresh air heater box is 100% different from the A/C whale tail (Top "Y-shaped" plastic to defrost the windows).
This conversion from A/C to just a heater box is going to be harder than I thought!
Old 10-13-2017, 10:09 AM
77&79F250's Avatar
77&79F250
Sounds like you need a part#18490 without part # 18547....
Or 18490 that has a different lower end...
Old 10-13-2017, 10:38 AM
Aaron-71's Avatar
Aaron-71
Aaron-71 is offline
You're correct on both accounts, also correct that either could work.
I'm debating modifying the heater box completely as this retro-fit isn't turning out as easy as I thought it would.
I can see now why many of you have deleted the A/C box, mounted an A/C block-off plate, and called it a day...
However... I need heat lol. Canada is cold!!!! especially in Saskatchewan!
I might do a write-up on my mods so that everyone can get a view of how I did it, what tools, the modifications, etc. Wondering if anyone would even use it tho lol... Lots of you guys seem satisfied with no heater in your truck.
Quick Reply: Heater Duct question
