1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
04 6.0 with history and current EOT issue...
Old 01-09-2017, 04:15 PM
jawjadawg's Avatar
jawjadawg
jawjadawg is offline
Truck currently has 250,000 miles. The oil cooler failed about 125k ago. The radiator, water pump, and oil cooler were replaced and EGR deleted. Ford Gold went back in and a coolant filter installed.
ECT and EOT sensors are +/- 1-2 degrees after overnight soak.
I switched to a 200 stat with EOT temp around 224 at 75 mph about a year ago. Then I started noticing my EOT was creeping until it recently hit 235. Last weekend I did Restore, and then Restore Plus. Removed the water pump and the plate at the top of the oil cooler. I used a pressure washer to backflush the oil cooler. With the water pump removed everything washed out instead of back down in the block. Replaced the water pump with a brand new OEM to rule out cavitation issues. Filled the cooling system with red CAT ELC and put in a 185 stat to replace the 200 stat I had been running. At 60mph, ECT is currently 188 and the EOT is 121 - or essentially the exact same temperature difference as before the flush when I had a 200 stat and 235 EOT's. Backflush and new waterpump did nothing for me.
I've read a tiny bit about an oil cooler bypass valve in the oil filter housing. Are these proving to be problematic instead of the oil cooler being clogged? How do I determine if I need to replace the oil cooler again, or something else? I would have thought the backflush would have at least given me a small improvement. NADA.
Thank you for the input!
Old 01-10-2017, 10:47 AM
jetjockey99's Avatar
jetjockey99
jetjockey99 is offline
You could have a problem with the oil cooler bypass, but I would suspect even though you flushed the oil cooler that it is still partially plugged, the passages are hard to flush due to design and size, also your thermostat at 185 degrees is too cold for a 6.0, an OEM is I believe 192 and the Mishi is 200. I run a Mishi in the winter and an OEM in the summer and see about a 7-8 degree spread year round, in the summer I can see 20 degree delta when towing about 18K. Also the test for delta's is at 65 MPH I believe so your numbers may be off.
Old 01-10-2017, 02:09 PM
jawjadawg's Avatar
jawjadawg
Oil cooler vs bypass valve
Thanks for the advise I suppose I'll change the oil cooler and see where that leaves me. I'll leave a post with results.
Old 03-30-2017, 02:25 PM
twoes47's Avatar
twoes47
twoes47 is offline
Does anyone know the part number for the screws for the cap you remove to backflush the oil cooler, I dropped one and can not retrieve it and the Ford parts guy looks at me like I am outer space.
Byrd.Dog
10-02-2017 09:25 PM
Bigfoot76
05-07-2013 11:34 PM
fatcowvtx
10-31-2010 01:31 PM
TampaDave
09-24-2010 06:43 PM
chromedom
05-19-2010 12:19 PM
Quick Reply: 04 6.0 with history and current EOT issue...
