Differential Cover
Old Jan 9, 2017 | 03:00 PM
ChrisMelton78's Avatar
ChrisMelton78
Differential Cover
Hey guys! I have a 1995 F250 4x4 with 7.3 Powerstroke. I just want to know if any of the later Super Duty diff covers will work on my truck? They look better and seem to have better heat-removing fins than the stock diff cover on mine.
Thank You in advance.
Old Jan 9, 2017 | 03:23 PM
fordpride's Avatar
fordpride
Get on from a 08 and longer bolts
Old Jan 9, 2017 | 04:00 PM
ChrisMelton78
So, is that the only year that will fit?
Old Jan 9, 2017 | 04:45 PM
fordpride's Avatar
fordpride
08-10
They have good cooling fins and a drain
Old Jan 9, 2017 | 08:07 PM
ChrisMelton78
Got it! Thanks for the info!!
Old Jan 10, 2017 | 10:57 PM
mcali2's Avatar
mcali2
Cool another thing to do.. or not... I don't know if i need it.
Old Jan 10, 2017 | 11:59 PM
nossliw's Avatar
nossliw
The sterling 10.25 and 10.5 covers are interchangeable. Most seem to have across the board similar fins. Mag Hytec covers are on all of our trucks, the AFR power covers are nice too and the view window I wish was on all covers...
Old Jan 11, 2017 | 07:59 AM
helifixer's Avatar
helifixer
I have never seen over 190 with my stock cover, even towing.
Old Jan 11, 2017 | 08:38 AM
knottyrope's Avatar
knottyrope
I think finned diff covers isn't all that, it more for looks and make you want a pretty rear end to clean more often
maybe if hauling in the dessert you might need one but if a old OBS hauler as never needed one why do they now?
Old Jan 11, 2017 | 09:05 AM
nossliw's Avatar
nossliw
I have seen as high as 230 in a stock cover for a prolonged period... they sure as chit help when towing. Only reason I put them on our trucks.
Old Jan 11, 2017 | 10:02 AM
mcali2's Avatar
mcali2
Someone should make a custom radiator cooled cover. Small trans cooler should work.
Old Jan 11, 2017 | 10:03 AM
knottyrope's Avatar
knottyrope
but then you need a pump
Old Jan 11, 2017 | 11:50 AM
helifixer's Avatar
helifixer
the load in my signature is 27,000 lbs from Grand Junction to central AZ in the summer 100+ degrees and my rear end never went over 190, my trans would climb up over 250.
towing my 5th wheel from San Diego through death valley in June it never went over 190, 120 degrees
Old Jan 11, 2017 | 11:59 AM
madpogue's Avatar
madpogue
That, and you have another potential leak source / point of failure. Where would you mount it where it would get some decent air, and wouldn't be vulnerable? I sure wouldn't want to take something like that off-road.
Old Jan 11, 2017 | 12:02 PM
97-psd's Avatar
97-psd
Here is what one looks like. I won mine as a door prize so all I had to buy was bolts. It gives the rice burners behind me something to look at. I don't wash it, so it stays pretty clean
