Differential Cover
Old Jan 11, 2017 | 12:05 PM
97-psd's Avatar
97-psd
Here is the pic
Old Jan 11, 2017 | 02:39 PM
knottyrope's Avatar
knottyrope
Originally Posted by helifixer
the load in my signature is 27,000 lbs from Grand Junction to central AZ in the summer 100+ degrees and my rear end never went over 190, my trans would climb up over 250.
towing my 5th wheel from San Diego through death valley in June it never went over 190, 120 degrees
That's enough to convince me I don't need a special cover.
Never saw one on a military vehicle I was behind.
I have replaced cracked aluminum ones. Steel ones just dent.
I just cant figure out why doing it with exception of more oil, sight glass maybe and a drain plug.
Old Jan 11, 2017 | 03:38 PM
nossliw's Avatar
nossliw
Not to disagree, my experience is from hauling double and a few triple tandems gooseneck trailers from Black forest CO, to Silverthorne over Eisenhower on a DRW Sterling 10.5 with 4.30s , maybe 60-70 degree days. Loads were logged timber 24-28,000 lbs scale verified. This is not a GROSS weight, including the truck we weighed in over 30k everytime. I could get the diff to 235 degrees within 10 minutes up I70, and it was hard to drop it much, seen more than that as well.
Trans stayed at 225-230 with a 6.0 cooler and upsized lines. I will agree a deep finned trans pan does nothing for temp, but the additional 6 qts can be nice.
I will agree 90% of them out there are for looks....
Old Jan 11, 2017 | 04:53 PM
fordman67's Avatar
fordman67
Originally Posted by 97-psd
Here is the pic
That one is affordable at 60-80$ and I will have one on my new doolie diff. Y? Cause bad a$$ness...
I'm not making excuses,just smoke
Old Jan 11, 2017 | 06:30 PM
97-psd's Avatar
97-psd
And they do look good!
If mine hadn't been free then I probably wouldn't have put one on it. But I do like how it looks
Old Jan 11, 2017 | 07:27 PM
knottyrope's Avatar
knottyrope
So you do like you read end to look nice and spiffy? do you wax back there too or go natural?
Some call bumpy or lumpy rear ends speed bumps aka hemi roids
Old Jan 11, 2017 | 08:09 PM
97-psd's Avatar
97-psd
My rear end looks spiffy all on its's own. So...el natural
Old Jan 11, 2017 | 10:06 PM
z31freakify's Avatar
z31freakify
I was thinking of adding one for looks but the huge 44 gallon fuel tank covers the whole pumpkin lol....
Old Jan 16, 2017 | 07:39 AM
Airstreamer67's Avatar
Airstreamer67
I bought a G2 aluminum cover because it has a drain for easy oil changes. It sure is purdy.
Also put a LubeLocker gasket for when I need to take it off for inspection and cleaning.
Old Mar 13, 2017 | 10:09 PM
ChrisMelton78's Avatar
ChrisMelton78
Here is the pic
Hey bud. By chance, can you tell me how much longer the bolts need to be compared to stock?
Old Mar 14, 2017 | 07:10 AM
Shawn MacAnanny's Avatar
Shawn MacAnanny
Everywhere i read said 1 1/4" 5/16 bolts but i got away with 1" using a lube locker gasket. Lowes sells them in stainless for like $1 each. I used regular bolt heads not the allen hex cap ones
Old Mar 14, 2017 | 12:39 PM
SNOWR8R's Avatar
SNOWR8R
I'd love to put some Mag Hytecs on mine. Diipstick/fill tube, drain plug, and an o-ring seal. No more sloppy RTV is worth it to me!
Old Mar 14, 2017 | 04:36 PM
  #28
fordman67's Avatar
fordman67
Originally Posted by knottyrope
but then you need a pump
Not if the outlet was properly placed in relationship to the ring gear.
Explore model t oiling system. It could work.
Old Mar 14, 2017 | 06:06 PM
  #29
Shawn MacAnanny
you'd probably just be better off zip tying an electric fan on the cover over the fins
Old Mar 14, 2017 | 06:35 PM
  #30
97-psd's Avatar
97-psd
I believe 1 1/4 are what I used as well
