P04DB Code (Crank Case Vent)
Old Mar 10, 2018 | 06:17 PM
  #31
Sun Baked Snoopy's Avatar
Sun Baked Snoopy
speperator
I was told yesterday that the part to fix it has been on national backorder since aug 2017.
Old Mar 10, 2018 | 07:43 PM
  #32
tracyclifton's Avatar
tracyclifton
Had mine fixed under warranty in October. They had the part in stock and had it done same day. Good luck.
Old May 10, 2018 | 07:11 PM
  #33
GeorgeS59's Avatar
GeorgeS59
My 2014 F350 just through theP04DB code today. Dealer confirmed it was the CCV filter unit and that they'd replace it under warranty. We're heading out on a 5000 mile trip tomorrow and he said it would not cause any issues. After reading these posts, I tend to agree with them that this should be ok until it gets replaced. FYI - light went out after pulling into the driveway and stopping and restarting the truck.
Old May 10, 2018 | 07:18 PM
  #34
tracyclifton
I can't remember how long mine came and went before I had it fixed. It was probably at least a year.
Old May 11, 2018 | 07:53 AM
  #35
bkuuz1's Avatar
bkuuz1
Agree
The code is for making sure you don't disconnect the connection.
When mine had the same code the remote start would not work because of the CES was active.
You could always get a dongle and an app like Torque Pro and clear it.
Old May 11, 2018 | 08:04 AM
  #36
tracyclifton
That's exactly what I was doing. Torque pro clears it but it eventually comes back. Its covered 100% by warranty.
Old May 11, 2018 | 04:55 PM
  #37
GeorgeS59's Avatar
GeorgeS59
Mine cleared itself once I got home and turned off and on the truck. However, I found my OBD2 bluetooth connector and was able to get it hooked up with OBDLink. Drove 460 miles today and no light - all is good (for now).
Old Jun 1, 2018 | 08:36 AM
  #38
my_crib_too's Avatar
my_crib_too
My 2015 visited the dealer a second time yesterday for this same issue. All fixed again, for free. The replacement sensor lasted almost a year. That's not great.
bruce...
Old Jul 30, 2018 | 11:40 PM
  #39
MFer's Avatar
MFer
Covered by Ford Customer Satisfaction Program
I’m getting the same codes on a f250 2014 with just over 50K miles, did not purchase extended warranty. However, according to Customer Satisfaction Program 17M04 – Crankcase Ventilation Oil Separator Assembly – 2014-2016 Ford F-Super Duty. This program extends the warranty coverage of the
crankcase ventilation crankcase ventilation
(CCV)
oil separator oil separator
assembly to 11 years of service or 120,000 miles from the warranty start date of the vehicle, whichever occurs first.
I took my truck to the dealer today, the guy behind the counter was clueless about the warranty extension but hopefully the computers will show him this should be covered.
Old Jul 31, 2018 | 06:49 AM
  #40
GeorgeS59's Avatar
GeorgeS59
My '14 F350 is going into the shop today for the sensor replacement. Just shy of 40,000 miles on the truck. Hope Ford can get it figured out and get a decent fix designed.
Old Aug 1, 2018 | 06:30 PM
  #41
MFer's Avatar
MFer
(CCV)
UPDATE, this was covered under ford warranty. Crankcase ventilation assembly replaced NO CHARGE.
Old Aug 1, 2018 | 06:57 PM
  #42
GeorgeS59's Avatar
GeorgeS59
Just got my truck back and there were no issues with getting this covered under recall/warranty.
Old Sep 18, 2019 | 12:57 PM
  #43
santafedave's Avatar
santafedave
Just got mine replaced yesterday. I was having serious shifting problems going uphill under load. The transmission would jerk so bad going from 6th gear to 5th and the last incident all the way to 3rd gear. It would jerk so bad that I thought the airbags would inflate. Anyway I got tired of dealing with it so I took it to the dealer and had them do a transmission service ($310.00) and they checked for metal in the pan and replaced the screen and put in new fluid. They did not find any shavings in the pan and the transmission wasn't throwing a code. They did find the 17M04 error with the P04DB code and replaced the crankcase collar and reprogrammed the PCM. I am hoping that this will solve my issues with the transmission shifting under load.
Old Oct 16, 2019 | 11:35 AM
  #44
Capttimb's Avatar
Capttimb
bruce...
Mine went in for the 2nd time as well a month ago......fast forward to today and the check engine light is on again!
Old Dec 5, 2019 | 04:32 PM
  #45
David Martinez's Avatar
David Martinez
Reminder of the code
