Backfire through carb.
Old Jan 26, 2017 | 03:33 PM
Tedster9's Avatar
Tedster9
It depends a bit on where he's at, elevation wise, in Texas. Guadalupe county tops out around 8k feet, and cam selection also affects this. It's not quite 1k ft = 1" of vacuum but it makes a big difference. Compression is the same way.
Old Jan 26, 2017 | 03:36 PM
jwcopeland's Avatar
jwcopeland
Around 600ft. Cannot give exact cam specs but it is a higher torque cam. Basically asked engine rebuilder to throw in a rv cam.
Old Jan 26, 2017 | 03:39 PM
Tedster9's Avatar
Tedster9
Did it break in OK? 20 minutes @ 2000+ RPM? Tbear pointed out a possible wiped cam lobe upstream. Not what you want to hear, I know but can't be ruled out? Although it wouldn't draw steady vacuum. Hm.
Old Jan 26, 2017 | 03:44 PM
jwcopeland's Avatar
jwcopeland
Break in was also fine, no hiccups. I was not there for it but a trusted friend did it by the book with proper break in oil.
rustywheel68
Apr 18, 2013 08:45 PM
smaki09
Jul 8, 2011 02:24 PM
1big79
Dec 9, 2003 11:33 AM
DrFord
Nov 2, 2001 11:42 PM
bufordt
Jun 22, 2001 06:46 AM
