can't find coolant zerex hd elc. what else can I use
I have to order the coolant zerex hd elc I want but I have the opportunity to get someone else to purchase my coolant today in store. What coolant can I get? O'Reilly has fleet charge I believe that has sca. Or just any heavy duty coolant with sca will be fine? I'm not wanting to add sca to coolant. Just drain and fill and go
That being said, Zerex has not caused me any issues in either my old or rebuilt engines, so...
Pretty sure that there's multiple ELC technologies that have been used over the years. Some are a lot more damaging than others.
The HOAT technology in Zerex seems to be relatively benign, but you can always research it yourself.
it us dumb but I'll finally have sca!!!! Thanks for all the help
One easy way to tell: Get yourself an antifreeze tester. That way you can see where you are at(either from the jug or in the engine), and go from there.
I always try to go a bit heavy on the antifreeze when draining and refilling(like 4 gallons of AF and 3 of water), because I know there's some water left in the block. With a tester, you can then check your mixture and see where you are at, figure out if you need to add more water or contentrate.
