So how to I turn the traction control on/off on a 2004 Mercury Mountaineer?
Today we had the first real (for NYC) snow storm since I got the truck in November, and I noticed myself sliding left to right a bit. I'm thinking it could be traction control, but how to I get to it?
I have a 2004 MM with of the options, including climate control. I did a quick search on MM traction control but found nothing, other than they all have it.
If you are sliding right to left, how do you figure it's traction control? Usually you get sideways slippage when both rear wheels spin. Very common in vehicles with functioning LSDs or especially lockers out back.
Traction control would cut the throttle when a wheel spins, and/or apply a brake to the spinning wheel.
My '98 had a noticeable engagement into automatic 4x4, but the one time I was in real ice and snow, it did a fine job IMO.
Auto 4x4 is not the same as your AWD, which should have no engagement issues or delays.
It also slides in the rain, but to a lesser extent. Tires appear to have plenty of life left.
Sounds like your AWD isn't working. If you can spin the rear tires on wet pavement, you are not getting much power to the front wheels.
The '98 was the SOHC 4.0 and would not spin the rear tires on wet pavement. It would try, but the Auto 4x4 got to it quick enough to prevent any sideways action.
Mechanic should try to read codes. Some transmission control issues show up, as well as other things that may or may not seem related but which could contribute to the issue.
johnkn
02-23-2010 09:09 PM
