p/s return line to booster
Old Jan 7, 2017 | 06:32 PM
timmyboy76's Avatar
timmyboy76
For some stupid reason, my truck decided to lose power today when exiting the freeway. D/s egt gauge verified it with no increase in temp when stepping on go pedal. After about a minute, I could feel it gain power. So, rolled into fuel station, and topped off tank. While filling, I popped the hood and started messing with the uvch and looking around. It was then I noticed that darn hose riding on top of a ton of wires. Pulled said hose up and sure enough, a wire is shafed clean off of insulation.
Anyway, something to check while looking around under there
Old Jan 7, 2017 | 07:48 PM
F350-6's Avatar
F350-6
Good info. I guess you're typing from a phone? Might want to correct a little spelling to make it easier to understand that the return hose had caused a chaffed wire.
Old Jan 8, 2017 | 12:24 AM
timmyboy76's Avatar
timmyboy76
Lol.. Yeah, my phone has a mind of its own. Also I saw Chris, my m/s tube riding atop a set of wires. May need to flip the clamp around to hold the tube up off them writes
Old Jan 8, 2017 | 08:39 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Not to be an *** here, but is it possible for you to go back to post #1 and edit it to make a bit more sense? I believe I got the idea of the first half, but I read the second half 10 times or so and still am not seeing the message.
Old Jan 8, 2017 | 08:57 AM
timmyboy76's Avatar
timmyboy76
Fixed.... Man, I couldn't even understand it
krl13
Jul 31, 2017 12:09 AM
GeorgePBurdell
1983 - 2012 Ranger & B-Series
Jul 10, 2015 11:28 AM
87f-150stepside
Jan 17, 2013 11:07 AM
HD Rider
Dec 20, 2012 10:49 PM
rijrnnr
2004 - 2008 F150
Nov 7, 2010 02:27 PM
