1976 f250 fuel pump eccentric
Need help with my eccentric for fuel pump. I have a 390 and had to change out the timing chain and gears. I went from a single to a double roller, edelbrock 7808. I have a two piece eccentric from old timing chain and need to know if I can install it tight, or swap to a one piece. If I can use a one piece any recommendations. The old timing chain gear has an off set to accomadate the two piece design. Edelbrock gear is flat. Thanks
akamacgyver
10-23-2012 10:58 AM
4wheelex
12-17-2010 10:45 PM
ceetwarrior
67
04-02-2005 04:26 PM
