66 Econoline Falcon
Old Jan 5, 2017 | 11:16 PM
Falcon123's Avatar
Falcon123
66 Econoline Falcon
I have a 66 Eco that has a dented front, between windshield and the bumper. If there a way to remove this to repair or ????
Old Jan 6, 2017 | 05:48 AM
Wolfster's Avatar
Wolfster
They can all be repaired. Depends on your skills or how deep your pockets are.
Old Jan 6, 2017 | 09:56 AM
Falcon123's Avatar
Falcon123
I understand this. I guess they were not manufactured to remove short of cutting.
Old Jan 6, 2017 | 11:01 AM
Wolfster's Avatar
Wolfster
No, they weren't. Really though, as far as ease of access goes, one of the easiest panels to work on.
Old Jan 6, 2017 | 12:44 PM
Falcon123's Avatar
Falcon123
Thanks Wolfster. When I worked for a communication company back in 67, my service van was 64 econoline. It would get stuck on wet grass, but a real kick to drive
Old Jan 6, 2017 | 05:23 PM
EmilBarnabas's Avatar
EmilBarnabas
Sometimes you can bang out the dent.
I've seen used front sheet metal on eBay every now and then.
Old Jan 6, 2017 | 09:34 PM
Falcon123's Avatar
Falcon123
If I could get to the back side of it would be no problem. I will watch Ebay for one. If nothing else I will have my son cut it out straighten it and weld it back. Thanks for the reply
Old Jan 7, 2017 | 10:40 AM
Wolfster's Avatar
Wolfster
Remove the headlight trim remove the air boxes on each side. If you have the underdash mount heater, you can drop it down. Remove the door card panel and any insulation. Remove letters. Easy access to both sides with hammer and dolly. Heat shrink if and as needed.
Old Jan 7, 2017 | 10:47 AM
Wolfster's Avatar
Wolfster
Don't "overthink" the problem. Don't "overthink" the solution.
Phathog
Jan 23, 2012 04:15 PM
kild1
13
Mar 4, 2010 11:16 PM
red and white truck
Aug 4, 2006 07:20 AM
brider
Mar 23, 2006 07:14 PM
73f350sc
S. California Chapter
Sep 17, 2004 12:06 AM
