Water in oil, 2000 7.3
Back story:
Bought the truck 1000 miles from home, ran great, checked oil it was black and well used, coolant was milky and degas bottle had some pressure in it.
Drove 200 miles fine, 75mph lots of power, no smoke, no overheating.
While cruising felt slight stumble, and lost hot air from the heater (started blowing cold), saw temp needle move slightly (still under 1/2 mark) and pulled over. Truck stalled on the offramp, and I was not able to get it to fire. I checked oil and it was same dark black. Coolant was low, down to about 2.5 gallons
Towed it home, oil change, coolant flush, new thermostat, rebuilt IPR, and it fired right up. Ran great, smooth.
Noticed slight haze out of the exhaust at idle, and puffs of white smoke when on throttle. Checked oil and it was milky
Where to look? Thanks
Received 3,701 Likes
on
oil cooler "normally" (not always) puts oil in the water or oil on the ground.
corroded timing covers will put water in oil.
g500xl
18
04-23-2014 08:23 AM
