How much cardboard do you use?
Old Jan 5, 2017 | 09:41 AM
PlumCrazy7's Avatar
PlumCrazy7
With the cold finally setting in here in Kansas I cut up some cardboard to block the radiator. The area open is now smaller than the AC condenser but the gauge still doesn't come up to the "normal" range (yes I know that factory gauges are crappy). So, how much do you block?
Old Jan 5, 2017 | 10:08 AM
Jarkill's Avatar
Jarkill
Where I live it can be 3 degrees at night and in the teens all day. Haven't had to block it off yet. Temp always runs right where it's supposed to. I'm guessing the mid west is a lot colder than that though
Old Jan 5, 2017 | 11:13 AM
Realslowww's Avatar
Realslowww
Where I am at you better have melon and I don't so I'm a cooked cracker...
Old Jan 5, 2017 | 01:54 PM
jayro88's Avatar
jayro88
We have gotten pretty cold here for extended periods of time (highs below 0*f) and have never needed to cover the grill at all. Maybe mine is different due to the van body?
Old Jan 5, 2017 | 03:09 PM
tradergem's Avatar
tradergem
Here is south central Minnesota I run my truck with only about a 6"x8" opening in my cardboard cover of my radiator. I also had to wrap my lower radiator hose with some insulating foam to help retain the heat.
The lower radiator hose gets a lot of cold air from under the radiator support on my truck. All you can do really is experiment and find out what works best for your truck.
Jim
Old Jan 5, 2017 | 11:10 PM
speedwrench72's Avatar
speedwrench72
i block 1/2 the rad on drivers side.
Old Jan 6, 2017 | 12:14 AM
The_Josh_Bear's Avatar
The_Josh_Bear
Jim
Dang that's some COLD. Here in western WA it's been in the teens at night for a week and that's pretty cold for us! Haha
Don't need cardboard with my setup...is it just getting heat into the cab faster or what?
Old Jan 6, 2017 | 08:02 AM
Biggun907's Avatar
Biggun907
I dont block off the Radiator at all on my 6.9, most guys do up here i havent needed to yet.
Old Jan 6, 2017 | 10:17 AM
Jarkill's Avatar
Jarkill
NorthBender! I drive through there every morning. I Lived on the ridge once upon a time as well.
Old Jan 6, 2017 | 09:21 PM
Chevy_Eater's Avatar
Chevy_Eater
Flea
Nov 24, 2007 06:47 AM
Wizardvette
1997 - 2003 F150
Jan 28, 2005 01:19 PM
danielboone4
Dec 23, 2004 02:58 PM
spikedog
1997 - 2003 F150
Jan 8, 2004 08:33 AM
Frank Lang
Jan 6, 2004 01:10 PM
