93 stumbles and dies
I have 1993 F-150 5.8 speed density.Having a problem with my truck. It dies off idle if you goose it off idle the truck will stay running but the air/fuel is way lean and take your foot off the gas the truck will stumble and then die. There is no check engine light. and If I unplug the throttle position sensor the truck will stay running and won't die. I have checked all sensors and wiring. The throttle sensor has 4.99 volts going to it and .80 at idle out of the signal wire.
I have good fuel pressure,no vacuum leaks.
Thanks for your help and input
The things that primarily affect fueling are the MAP sensor, Coolant Temperature Sensor and the Air Charge Temperature sensor. The TPS is primarily used for "transients".
Since you swapped the computer and the problem persisted, it's likely to be a sensor issue. Also just to be sure, what is "good" fuel pressure?
Fordman_Evs
03-23-2007 05:32 AM
short76
10-24-2006 06:19 PM
Benjaminalot
05-22-2002 03:34 PM
