Oil cooler leaking.
Old Jan 4, 2017 | 11:47 AM
Patrick Tompkins's Avatar
Patrick Tompkins
Oil cooler leaking.
Hey im patrick, My navigator is fubared. I have oil in my coolant. So I know my cooler is bad. Is there anyway to delete this SOB? im in a bind please respond.
Old Jan 4, 2017 | 01:18 PM
alloro's Avatar
alloro
The coolant to oil leak culprit is usually the intake gasket. The intake manifold has to come off to fix it. Then obviously you need to do an oil change after.
Old Jan 4, 2017 | 03:57 PM
Patrick Tompkins
I have oil in my radiator. The Oil cooler is bad. How do I delete oil cooler is it possible?
Old Jan 4, 2017 | 04:15 PM
pdqford's Avatar
pdqford
What vehicle?
Old Jan 4, 2017 | 05:58 PM
alloro's Avatar
alloro
You can cut the cooling lines running to the cooler, but that raises two problems. The first is you'll have to install an auxiliary cooler so you don't burn up your tranny. The second problem is that since the cooler is leaking into the radiator you'll have to be sure to plug the two cooling ports nice and tight or coolant will come out of them. You best bet is to just change the radiator and flush out the cooling system.
Oh no 6.0
Apr 22, 2017 09:24 AM
genscripter
42
Aug 23, 2015 02:29 PM
vtown00
21
Feb 12, 2015 08:13 PM
BIG-DADDY-F350
Jan 11, 2015 09:49 AM
dzzavid
Oct 1, 2009 05:14 PM
