DEF Question
Old Jan 4, 2017 | 09:33 AM
bodytech's Avatar
bodytech
Originally Posted by troverman
Interesting. DEF usage is pretty much continuous and is not used solely during a regen. In fact, it is likely DEF is not injected at all during a regen, because it would lower exhaust gas temperature.
There is no "reset" after a refill - there are probes in the DEF tank which measure level through continuity. You should immediately see the DEF gauge register full after refilling.
I am sorry that is my bad I was confused to how the system worked.
I understand how it works now.
I will probably go back to the dealer and request they check the level and go from there. I contacted ford and they said IF they indeed filled all the way it should have reset the next time it was driven.
Old Jan 4, 2017 | 10:03 AM
troverman's Avatar
troverman
No apologies needed...that's what this forum is for...shared learning!
Old Jan 4, 2017 | 10:10 AM
f350ktm's Avatar
f350ktm
Duplicate question posted
Old Jan 4, 2017 | 11:39 AM
bodytech's Avatar
bodytech
All better.
Sooooooo according to the dealer they said oops.
I returned they checked and it was low 5.5 gal. They said the nozzle on the jugs are messed up and that it acts like it's full but it's not. Hmmmm
Whatever, so it's filled and the gauge reset as soon as I started the truck.
Thank you for everyones help.
Old Jan 4, 2017 | 11:46 AM
HouseMouse's Avatar
HouseMouse
All better.
Good for you. Always check the dealers work. We are all human and mistakes are made....
Old Jan 4, 2017 | 01:09 PM
ravill's Avatar
ravill
I wonder what DEF in the fuel tank would do? Act like water I suppose.
Old Jan 4, 2017 | 01:21 PM
EpicCowlick's Avatar
EpicCowlick
That's an $11,000 mistake. A few have tried and everyone failed... You don't want to be like THAT guy.
Old Jan 4, 2017 | 01:22 PM
Rob_17's Avatar
Rob_17
Im sure there would be damage involved! if not caught in time, replacement of the fuel system at the minimum. thats $8-9k easy
Old Jan 4, 2017 | 01:36 PM
PwerStroke99's Avatar
PwerStroke99
This is so true!
Old Jan 5, 2017 | 09:09 AM
bodytech's Avatar
bodytech
I am very happy that was not the case.
Old Jan 8, 2017 | 06:29 PM
FOUNTAIN 1's Avatar
FOUNTAIN 1
Originally Posted by PwerStroke99
This is so true!
well ,, I'm getting a locking gas cap .. that's too easy to destroy someones truck .. a little sugar .. oh I mean def in that gas tank trick ,, yikes
Old Jan 9, 2017 | 10:23 AM
bodytech's Avatar
bodytech
Right, I am with you on that one.
maticuno
Jul 8, 2019 09:32 AM
Norfra
6.7L Power Stroke Diesel
Mar 6, 2016 05:44 PM
Major Marvin
30
Nov 12, 2010 06:15 PM
Labgal
Nov 2, 2005 12:15 PM
Teo
Aug 16, 1999 09:43 AM
