Well I am a licensed sheet metal worker as well so measurements and power tools second nature lol
I came from that stock. Granddad was a tin knocker. But the other side of the family did different trades and I picked up those instead. Too bad. It's dying art with so much prefab now.
Very true I learned from my grandfather and my dad got my sheet metal,plumbing,refrigeration and gas license from them as well it was a family run shop till my dad past and now I run it and my 2 boys 21 and 18 want no part of it so sad
I would have a dealer do it, I could see doing a B&W flip over ball at home with one hole but to have to holesaw 5 holes and get them all exact would be a feat. I would go to the dealer you bought your truck from and see how well they take car of you on labor/parts to install it since Ford for what ever reason thinks no one tows with a 2x4.
I believe that the part required for the 4x2 fifth wheel prep is different from the 4x4 fifth wheel prep. Ford probably decided not to handle both parts at the factory due to low demand for 4x2 and even lower demand for 4x2 with fifth wheel prep.
I've put in two Reese under bed mounts before ford brought this option to the table. After you mount the the rails under the bed you screw a pointed 6" bolt up through the puck mounts into the bottom of the bed and it dimples it.
If your bed wasn't pre dimpled from the factory then this is a simple solution to line up the holes.
There are two fifth wheel prep kits for the 2017 SD, Hitch Prep Package - 5th Wheel / Gooseneck Includes Outer Level Frame Brackets (part # HC3Z-5F057-A) and Hitch Prep Package - 5th Wheel / Gooseneck, Includes Inner and Outer Level Frame Brackets (part # HC3Z-5F057-B). Our unicorn (F350 XLT Super Cab 4x2 6.7L Long Bed) requires the one with inner and outer level frame brackets.
I order the right P/N but I wander how high I got to pick up the bed to slide the bracket under.
