HEEELP! - Exhaust Valve Stem Caps
Old 08-26-2003, 09:38 PM
90f150moneypit's Avatar
90f150moneypit
90f150moneypit is offline
I posted this in the small block W forum but not sure if anyone there can answer this and I really do need help this time. Sorry about this!
How do you remove the exhaust valve stem caps to remove the Exhaust valve spring?!!!
Does this take a special tool? I have the valve spring compressed but the cap is on there but good, keeping me from pulling the spring.
I swapped an intake spring without a problem because they have the regular locks. How do I remove the cap, my book just say's remove it! A lot of good this book is!
Old 08-27-2003, 08:09 AM
quentrm250's Avatar
quentrm250
quentrm250 is offline
They just pull off. Sounds like for some reason they are just stuck. Try tapping it with a plastic or bronze hammer...LIGHTLY.
I would try tapping on the sides first and then on the top. Good Luck!
Old 08-27-2003, 10:35 AM
DW2455's Avatar
DW2455
DW2455 is offline
Theres nothing that holds them on, probaly oil under them ctreating a suction take a apir of needle nose pliers and snugly grab them on the side and pull them off. good luck DW
Old 08-27-2003, 07:04 PM
90f150moneypit
Thanks guy.
I found out they are rotators, not caps. For anyone else doing this, all you have to do is grab a screwdriver and knock them down. The keepers actually hold them up.
Note to self; don't drop the keepers, they are hard to find in the gravel!
Old 08-28-2003, 07:23 AM
quentrm250's Avatar
quentrm250
Actually they are rotator caps
Glad you got them figured out.
mueckster
03-02-2011 02:17 PM
safetysandy2
1997-2006 Expedition & Navigator
04-20-2010 03:24 PM
rainbowATF
04-18-2004 05:45 PM
90f150moneypit
08-26-2003 06:22 PM
Quick Reply: HEEELP! - Exhaust Valve Stem Caps
