Duel Steering Stabilizer?
Old Jan 2, 2017 | 04:16 PM
Amicus's Avatar
Amicus
Was thinking of getting one on my 06. Just wondering if anybody has some experience with them. How do u like them and did they help with steering? My steering seems a little loose and was thinking duel stabilizers would help.
Thankd
Old Jan 2, 2017 | 04:26 PM
seijirou's Avatar
seijirou
Easy enough to pull yours off and check if it's in good shape or not. If you have tires larger than 35" dual stabilizers begin to make sense. Otherwise it isn't needed and if you have loose steering, it's something else.
Old Jan 3, 2017 | 01:46 AM
87crewdually's Avatar
87crewdually
Like said above. To be blunt, dual stabilizers are a bandaid. If there is something loose, repair or replace it. Don't mask it.
Check the obvious. Tie rod ends, ball joints, hub bearings, & track bar to start. Also check the play in the box and steering shaft. The steering box's do wear out.
Old Jan 4, 2017 | 12:41 AM
2006F250SuperDuty's Avatar
2006F250SuperDuty
I'm also interested in replacing my steering stabilizer. Anybody have an idea as to which ones are the best for single and dual stabilizers?
Old Jan 4, 2017 | 11:39 AM
Amicus's Avatar
Amicus
If I understand this right, an aftermarket duel stabilizer would be placed/located differently and in addition to the oem stabilizer? That's why I asked the original question.
Old Jan 4, 2017 | 03:46 PM
seijirou's Avatar
seijirou
It replaces the oem stabilizer, but is essentially in the same place.
It's there to resist uneven road surfaces from turning the wheels. As your tires get bigger, the leverage the road has to turn the wheels gets greater. When the front wheels want to turn on their own and rip the steering out of your grip on uneven surfaces is when even more dampening makes sense.
If you're going down a paved road and the steering wanders or is loose, that's not a dampener problem and adding dual or even 10 of them won't help. That's a linkage problem or a worn out steering box problem, or both.
springdale6
Apr 1, 2018 09:26 PM
mrdoughnut
Jun 27, 2012 10:16 PM
Sickler1
Aug 14, 2011 12:36 PM
f350rebel
Feb 28, 2008 10:38 PM
'94Nichols
1978 - 1996 Big Bronco
Oct 22, 2007 06:53 PM
