Sponsored by: Auxito
rough idle cont....
Old Aug 26, 2003 | 09:03 PM
methos5044's Avatar
methos5044
rough idle cont....
I posted a thread about my 97 F-150 having a rough idle and it trying to stall. I'm having more problems, I was told it was probably the IAC, now would that screw up when it's humid? I'm having most of my problems when it's hot and humid and today was the first time driving in the rain and man was it screwing up big time. Between 1700 and 2000 rpm it would try to stall out. My accelaration is pitifull. Sometimes it accelerates fine and other times it's a real dog. It sputters until about 3000 rpm then it takes off like a SOB. Would the IAC do all of those problems or do I have a multitude of problems?. These are the things I've done so far:
clean MAF sensor
checked for vacuum leaks - none
With spray bottle I sprayed every connector and sensor i could find with water - nothing.
My neon was doing this and it was the O2 sensors but I don't have a check engine light coming on and my scanner showed no codes. Please help
Old Aug 26, 2003 | 09:45 PM
LxMan1's Avatar
LxMan1
rough idle cont....
Sounds like plug wires. They may be shorting when damp.
Jimmy
Old Aug 26, 2003 | 10:16 PM
methos5044's Avatar
methos5044
rough idle cont....
i sprayed the coils and fuel injectors with water and it didn't do anything, I waited till everything was dry.
Old Aug 26, 2003 | 10:33 PM
JeremyH's Avatar
JeremyH
rough idle cont....
You might have a loose vacuum line somewhere.
Old Aug 26, 2003 | 10:54 PM
AegisSailor's Avatar
AegisSailor
rough idle cont....
Well, if the problem doesn't go away when you apply gas, then you can rule the IAC out. All it does is hold the butterfly valve open when there is no tention on the throttle cable.
I'd have to agree with lxman1 about the plug wires, you may want to change them out regardless. Also check the condition of the air filter.
Old Aug 27, 2003 | 07:11 AM
methos5044's Avatar
methos5044
rough idle cont....
the air filter is new, It's engine is the 5.4. As far as I know it doesn't have plug wires it has coils and each plug. It had a tune up about 20,000 miles ago. I checked all vacuum lines and found no leaks
Old Aug 27, 2003 | 08:02 AM
AegisSailor
rough idle cont....
I'm just speculating here, but could the TPS cause this type of problem?
Old Aug 27, 2003 | 05:38 PM
aldridgec's Avatar
aldridgec
rough idle cont....
I think the MAF sensor it self may be bad. Moisture in the air causing it to read incorrectly, especially when raining (shorting it out in a way). You may try driving without it plugged in and see if its any different/better. I don't know if it will even run on a Ford without the MAF but its a decent test on other vehicles.
