20 inch rims
Old Jan 1, 2017 | 08:16 PM
pkthomas's Avatar
pkthomas
20 inch rims
http://fortsmith.craigslist.org/wto/5931341325.html
This guy says he had these on his excursion without spacers. I looked in the tech file and could not find any 20s listed for our trucks. Did I miss something? If there is a possibility the will work without spacers, are they close to a good price?
Old Jan 1, 2017 | 08:29 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
They'll bolt on but will be sucked about 2" into the fenders on all four corners without spacers.
Old Jan 1, 2017 | 08:41 PM
PSUhoss's Avatar
PSUhoss
I run those same wheels on my excursion with a set of Freds spacers and really like the look as do others.
What I don't remember seeing on my wheels are all of the holes around the hub. Did it look like they were drilled out?
Looks scary!
Old Jan 1, 2017 | 08:42 PM
PSUhoss's Avatar
PSUhoss
(Double post)
Looks REALLY scary!
Last edited by PSUhoss; Jan 1, 2017 at 08:43 PM. Reason: So scary I had to post it twice!
Old Jan 1, 2017 | 09:29 PM
pkthomas's Avatar
pkthomas
He sent the pic. I did not see them in person. I don't think it is worth 2 hours each way for wheels that won't work.
Old Jan 2, 2017 | 06:48 AM
mecdac's Avatar
mecdac
They appear to be both "lug-centric" and "hub-centric" applications.
Old Jan 2, 2017 | 07:16 AM
WE3ZS's Avatar
WE3ZS
Either that or they have been redrilled for a slightly different bolt pattern, the non-factory holes look to be a tiny bit inside the stock bolt circle. Maybe the OBS bolt pattern?
Old Jan 2, 2017 | 07:41 AM
PSUhoss's Avatar
PSUhoss
Originally Posted by WE3ZS
Either that or they have been redrilled for a slightly different bolt pattern, the non-factory holes look to be tiny bit inside the stock bolt circle. Maybe the OBS bolt pattern?
I think you are right Tom. Someone drilled the wheels to get another bolt pattern, at least when compared to the wheels on my excursion.
scary stuff....
Old Jan 2, 2017 | 10:52 AM
Apocalypse's Avatar
Apocalypse
You couldn't give me those. I love that wheel, but redrilled... hell no!
Old Jan 2, 2017 | 10:59 AM
sessland's Avatar
sessland
x2
There's no reason to gamble on something like that
Old Jan 2, 2017 | 01:49 PM
7.3Excursion4x4's Avatar
7.3Excursion4x4
You can run factory 20" but have to have spacers. Like others above said, no way in the world I wold run those with the extra holes drilled into them.
Here's mine with PlastiDip on them
Old Jan 2, 2017 | 02:31 PM
Mdavidson1974's Avatar
Mdavidson1974
How is that plastidip holding up for you? I had a friend do a chrome wheel and it was peeling writhin a week... I'm certain he did something wrong just wondering how it wears when done correctly
Old Jan 2, 2017 | 03:15 PM
Apocalypse's Avatar
Apocalypse
DAMN THOSE LOOK GOOD IN BLACK!!!!!
Old Jan 2, 2017 | 03:18 PM
Apocalypse's Avatar
Apocalypse
I said I wouldn't take those if you gave them to me but after a few minutes of thought I would happily take them...
I can ALWAYS use more aluminum
Old Jan 3, 2017 | 06:08 PM
7.3Excursion4x4
Its holding up way better than I thought. Only one small chip around a wheel weight and another on a rear center cap where I tried to pry it off.
I watched several of PlastiDip's youtube video's from their site and followed them exactly. 5 thin coats and its been great.
I also did the chrome trim strip in the side cladding and its holding up great as well.
