@006 E250 service
Old Jan 1, 2017 | 01:05 PM
Derbyman's Avatar
Derbyman
@006 E250 service
Have a 2006 E250, 80,000 miles took into the dealer for brake work when they were done they said I needed to have these things done Fuel Sys.,Intake Sys. cleaning service, Auto Trans, Cooling,Power Steering fluid exchange. No mention of the oil change I know I'm due to have done. Question is are any of these services necessary? If so in what order of importance should they be done. By the way truck is out of warranty
Old Jan 1, 2017 | 03:52 PM
vettex2's Avatar
vettex2
it's called a wallet flush
Dealers are notorious for this
You might need some services. Take a look at the fluids and see if they are discolored.
Old Jan 2, 2017 | 03:00 AM
MoeDaMaster's Avatar
MoeDaMaster
No kidding, just find a dealer for an oil change and maybe a transmission flush.
Y Of course only if you do not want to risk ruining your driveway with oil
Intake an fuel system? WTF...pick up an air filter at NAPA and a can of techron concentrate. Replace the air filter (really easy) and add the additive to the fuel tank as directed on the can. That's all there is to it.
For the power steering:
Grab a quart of MERCON (V) ATF and a syringe from the hardware store, open
the reservoir for Power Steering fluid and pull out the old fluid, dumping it in another container. Should be around 100 ml. Replace with same amount of new fluid in the reservoir, put on lid, drive a mile. Repeat until you took out a quart. You're done when the bottle of new fluid is empty. Not totally effective, but a cheap way to keep your power steering alive without having to pull any hose or risking leaks.
saved you $100s...i
Old Jan 2, 2017 | 08:52 AM
Wildman25's Avatar
Wildman25
That about said it all.........Dealers are notorious for up-sales and following the OEM's spec's to the letter, which is fine.
There are intervals at which fluids should be changed as per the Factory Service Manual (FSM) You'll also find this info in the vehicle's owners manual (if you have one?)
At 80K, that's a service point, and the dealer has giving you the "list" from that point. Do you follow that list? That's up to you, most people do not follow the "written list" to the letter.
From what you wrote, if you can do some of the work yourself, that's great, most of us on here do most, if not all our own work
If not, find a good local corner garage, with a ASE certified mechanic, and keep away from the "All Car Care Centers" their worst than the dealers for up-sales and throwing parts at the thing until your wallet goes bust
For your 2006, I take it, you just got it and don't know who did what and when??
First, Do NOT use MERCON (V) ATF for the power steering fluid change, from '05+ (or earlier) the spec's call for Synthetic Power Steering Fluid, in fact, I've never used ATF for the power steering, always specific power steering fluid. ATF will burn out the seals for the power steering, and cause leaking.
This is not really needed to be done, just check that the fluid is at the proper level, and top of with the correct fluid.
In your case, I would do the coolant flush, again, there are special steps to do this, not just drop the old and replace, it's almost a power type flush for the coolant. Coolant that now 11 year old, time to replace.
Tranny flush, that's up to you, but again, there are special steps to do this correctly.
Fuel system cleaning? Couple cans of Lucite in the fuel tank will do this.
Overall.........at 80K, I would do coolant flush, check all fluids, new air filter, and go as far as replacing the plugs and boots/springs. Check the COP's and do a scan for codes. And any PM issues.
Old Jan 2, 2017 | 09:36 AM
MoeDaMaster
Ok, i have a 2004 that uses ATF. Sorry about that!
Old Jan 2, 2017 | 09:48 AM
Wildman25's Avatar
Wildman25
No problems........just want to steer the OP in the right direction
Spec's changed from some year models, and with the wrong fluid, it could cause problems.
Old Jan 2, 2017 | 11:24 AM
MoeDaMaster
ok that's cool
04F-250mark
Oct 1, 2014 07:53 PM
moose_j9
Apr 28, 2011 09:14 AM
newr
1983 - 2012 Ranger & B-Series
Jan 20, 2010 07:33 AM
Scout
Mar 16, 2009 03:54 PM
plane
Apr 19, 2006 04:03 PM
