Possible causes for empty HPOP reservoir? !?!
#47
I wanted to see what was actually happening inside under the Res Cover so I removed the top cover and put some bolts back in to hold the lower seal and it in place. I cranked it for about 2x 30 second rounds before getting a small amount of oil to flow from this port and it just spills over into the port under it. It gurgles and gurgles as the level slowly falls back down this port for the next 30 min.
I could **** more flow than this. I then removed the checkball on top of engine and Inspected. Looked normal to me but what do I know. Beside from what I understand its open during operation anyways and primarly used for antidrainback of the res while sitting but it was right there so why not inspect.
I drained the oil hoping to use my bore scope through the oil pan plug to confirm the pickup is still on but couldnt see a thing.
I was able to remove filter and manually get a pick in the valve in the housing and it moved freely somewhat but without knowing how much it should move Idk,
Got cold and dark and going to rain for three days so I pulled the block heater and let the coolent out. It will be all drained and ready for me in a few days when I have time to pull cooler to inspect the valve in the backside of the filter housing.
To the left the "new" check valve.
To the right the one in my engine.
I tried starting my truck up with the HPOP reservoir plug remove and no oil came out while cranking, I took a quart of oil out and refilled the HPOP with new oil put the plug back on, cranked it and it started righ up and stayed running like it always has. Ill check it in the AM. And see if the HPOP drains again.
#48
#50
#54
All the way down. I took off the HPOP resevoir bolt and started the truck up and no oil came out when I cranked the engine over. So that leaves the LPOP or the oil cooler end cap check valve. I know it's not the pick up tube, I lifted her *** up same scenario it's only when cold or first start of the day, once warmed up she runs great, no HPOP drain in a span of 8-10 hours.
#55
#58
#59
https://www.google.com/imgres?imgurl...act=mrc&uact=8
https://deadheaddiesel.com/7.3-powerstroke-problems/
I have never seen that last site. it looks pretty comprehensive.I wonder why it's never been mentioned.
