Power drum upgrade
Old Dec 29, 2016 | 09:39 AM
Raptor10's Avatar
Raptor10
Power drum upgrade
All,
I have a 1963 F350 dully that I'm just starting to update the brake system. I'm wanting to upgrade to power drum with the inclusion of a booster. Do I need a two well master cylinder and would I need any extra external parts i.e. Proportioning valve etc. can anyone recommend a booster and MC or send me to a link as I'm sure this is a much discussed topic.
Thanks
Dan
Old Feb 9, 2017 | 06:32 AM
ihcc104's Avatar
ihcc104
NOS OEM Ford Reman. 1963 1966 Truck Pickup Brake Booster 1964 1965 F100 F250 | eBay
I realize this is old, but this is the booster you need and the MC that would have come with your truck, I have a 64 F350 DRW. A little too steep for me, but they dont come up too often.
Old Feb 9, 2017 | 06:41 AM
Raptor10's Avatar
Raptor10
Your telling me....your the first to answer and Ive been checking since posting it. Starting to worry that my posts had B.O. Thanks, I've been waiting on someone.....
Dan
Old Feb 9, 2017 | 08:08 AM
66v8baby's Avatar
66v8baby
You can use any power drum booster. Here's cheaper one that includes a new MC:
1964 Mercury Caliente Comet power brake booster & drum brake master cylinder | eBay
Old Feb 9, 2017 | 08:16 AM
ihcc104's Avatar
ihcc104
well yeah of course you can use any one, it depends on what you are looking for. I wanted an original one. If you buy one like that you'd have to make a bracket to mount it at the required angle. I saw one on eBay a year or so ago and bought it for $60 w/o a MC to have as a spare.
Old Feb 9, 2017 | 08:24 AM
66v8baby's Avatar
66v8baby
In your initial post you did not mention you wanted an original, and asked if you needed a 2 well, which of course would not be original. If you already have a drum brake booster that doesn't require adapters or modification, then all you need to do is bolt your MC to it.
Old Feb 9, 2017 | 08:40 AM
ihcc104's Avatar
ihcc104
I am not the OP
Old Feb 10, 2017 | 01:39 AM
Raptor10's Avatar
Raptor10
Yep, your right....I am. But I'm just glad I'm getting responses to the original thread. Its all good information though, thanks
Old Feb 10, 2017 | 01:45 AM
Raptor10's Avatar
Raptor10
application
Will this work on a 1963 F350? The Ebay vehicle application says it doesn't fit the truck.
thanks
Dan
Old Feb 15, 2017 | 06:59 PM
ihcc104's Avatar
ihcc104
thanks
Dan
It does not fit the truck directly... the trucks have a larger booster and a 4 bolt pattern on the booster, not 3. I am sure you can get anything to work with enough fab work, but no this would not be "correct" for a 63 truck. The only one that would not require mods would be the one I posted unfortunately
Old Mar 2, 2017 | 01:59 AM
Raptor10's Avatar
Raptor10
Thanks Cory,
While I'm not a stickler for stock original, I do want to stay away from modifications if at all possible. Having said that I will try to stay with something original or at worst minor modification. I appreciate the information.
thanks
Dan
Old Mar 2, 2017 | 08:08 AM
66v8baby's Avatar
66v8baby
I'll try to pay more attention to whose "speaking". Here's one that will take less modification. As the ad states, you will need to elongate the holes in your MC to fit the bolt pattern, but that should be pretty easy with a die grinder.
1961-1972 8" (zinc) Ford Galaxie Power brake booster & pedal linkage G8 NEW | eBay
Old Mar 2, 2017 | 11:01 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1967 was the first year that FoMoCo installed dual master cylinders on F100/350, Bronco, Econoline and Passenger Cars.
Old Mar 3, 2017 | 05:59 AM
User 71024's Avatar
User 71024
Just my 2 cents. If you are going to take the effort to improve your brakes then you will want to do the dual MC. When a single master fails you have "0" brakes, when a dual fails you at least have a prayer.
All the vehicles I have upgraded I just bought a booster/master from the first year listing of that vehicle that had a dual. According to ND, that would be the 67.
Old Mar 3, 2017 | 12:11 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Just pull the e-brake handle! Everyone thinks you'd be without brakes but if the rears are not adjusted to make contact neither will work anyway.
