More PCM Questions
Old Dec 29, 2016 | 06:13 AM
BWD444's Avatar
BWD444
More PCM Questions
For my engine a 1995 4.9l there are 4 possible PCM's available not including the California one which I do not live in Cali so forget that one. Is there someone who knows the differences between them by their code numbers? I will list them for reference, my truck has the 4.9l and the E4OD tranny EECIV diagnostics. I swapped this engine in so I do not have an original PCM for reference which is why I am trying to decode the differences in these PCM's if possible.
F5TF-12A650-BAA
-BAC
-BBA
-BBC
Thanks, Brian
Old Dec 29, 2016 | 06:24 AM
BWD444's Avatar
BWD444
I should post my calibration number it is 7-76A it is a 1997 F350 vin #1FTHF36H0VEB12355
Brian
Old Dec 29, 2016 | 10:34 AM
rla2005's Avatar
rla2005
I'm confused....the first post states you have a 1995, then the second one a 1997 F350.
The VIN you posted is for a 1997 F350 (F36) with a 5.8L engine (H).
What exactly are you trying to accomplish?
Old Dec 29, 2016 | 10:44 AM
Lead Head's Avatar
Lead Head
Apparently he swapped a 1995 4.9L into a 1997 F-350 that originally had a 5.8.
Old Dec 29, 2016 | 05:49 PM
BWD444's Avatar
BWD444
PCM Questions
Lead Head you got it, I put a 95 4.9l in a 97 F350 and am trying to find the correct PCM to get it running. Also if possible I would like to know what the differences are in the various PCM's that fit this engine and transmission combo that I listed.
Brian
Old Dec 29, 2016 | 05:59 PM
Lead Head's Avatar
Lead Head
Wrong thread.
Old Dec 29, 2016 | 07:58 PM
BWD444's Avatar
BWD444
PCM Questions
I do not know what an air bag has to do with it but F350's of this era do not have air bags. In my state trucks over 8000gvw before OBDII do not get emissions tested just a general inspection. So I can put any engine I want into this truck it just has to run and be safe to operate. I see in other posts that there are people who can look up PCM numbers and use the emission code to check compatibility that is what I am after if I need to give more info let me know.
Brian
Old Dec 29, 2016 | 09:55 PM
Lead Head's Avatar
Lead Head
Sorry, had too many pages open and entered my text into the wrong one. Just use any 1995 non-California 4.9L E4OD Computer. It should work.
Old Dec 30, 2016 | 07:20 AM
rla2005's Avatar
rla2005
The problem is the heavy duty trucks use a different air injection system. I believe Subford mentioned before some of the F250HD/F350 may use a single AIRB solenoid versus both an AIRB and AIRD on the F150/Bronco. So depending on the donor engine and what is already in the truck the OP needs to source a compatible computer to keep the Check Engine Light off. There are ways around that by keeping the solenoid(s) electrically connected, but not attaching the vacuum lines.
Old Dec 30, 2016 | 11:56 AM
Lead Head's Avatar
Lead Head
That wont matter. To swap in the 4.9, he would have had to swap in the entire 4.9 harness since it's completely different. Whatever hardware the 351 had is irrelevant at this point.
Old Dec 30, 2016 | 01:11 PM
BWD444's Avatar
BWD444
I got the whole engine harness and I have it all connected up ready to run. In my state this truck does not need to pass emissions so I removed the air injection but kept the EGR and no cats .
Barry Lloyd
Aug 28, 2018 01:36 PM
krazirbar
May 9, 2010 12:23 PM
Vinford
23
Mar 25, 2006 05:20 AM
littleme13
Feb 27, 2006 06:39 PM
