Battery idiot light
Old Dec 27, 2016 | 05:17 PM
Cryptmaster's Avatar
Cryptmaster
Battery idiot light
Battery light came on today. Checked voltage with truck running and only getting 11.8 / 11.9 volts at each battery. Alternator shot or ?????
'04 F350
Old Dec 27, 2016 | 05:24 PM
akblackfoot's Avatar
akblackfoot
That's what it was with mine. Many gave advice not to run it until you get a new Alternator so you don't fry your FICM also.
Old Dec 27, 2016 | 05:42 PM
Cryptmaster
any advice on size/brand to buy? or NOT to buy for that matter?
Nothing special in truck at moment all stock.
Old Dec 27, 2016 | 05:43 PM
69cj's Avatar
69cj
Once you have replaced the alternator I would also ave both batteries load tested separately.
Old Dec 27, 2016 | 05:49 PM
Cryptmaster
batteries both replaced this past July.
Old Dec 27, 2016 | 06:30 PM
69cj's Avatar
69cj
I would still have them tested. They give warranties because things fail.
Old Dec 27, 2016 | 06:40 PM
Burgess090906's Avatar
Burgess090906
At the very least, get an 05 140 amp unit. 03-04 has a 110 amp stock.
Old Dec 27, 2016 | 06:43 PM
Cryptmaster
Good point, Have to go to the parts store first thing in the morning anyway. Thanks
Old Dec 27, 2016 | 06:49 PM
WatsonR's Avatar
WatsonR
If you buy from Advance Auto, buy on line, use code TRT30 to save $50 off purchase, do in store pick up.
Old Dec 27, 2016 | 07:06 PM
Cryptmaster
Does the '05 drop right into an '04? website says it doesn't fit?(not that i really trust the parts store about what fits and what doesn't)
Old Dec 27, 2016 | 07:12 PM
87crewdually's Avatar
87crewdually
Tell'em you want the upper/top alternator for an 05 dual alternator F-350. This will get you the highest amp. Alt. YES it will fit.
Old Dec 27, 2016 | 11:06 PM
Restlesswildman's Avatar
Restlesswildman
What he said!
Old Dec 28, 2016 | 11:29 AM
53jimc's Avatar
53jimc
Here's what I bought at advance. It isn't a "super" alternator, but seems to be doing ok. My truck is an '05.
CARQUEST Alternator - Remanufactured - 140 Amps 8478A: Advance Auto Parts
Old Dec 29, 2016 | 10:16 AM
Cryptmaster
Thanks to all for your input. What should have been an easy five minute job, turned into a 2 hour job, due to my own stupidity on removing the belt. Royal pita to get it back on if you don't lock the tensioner in place (which I didn't know you could do). But alas no more idiot light, both batteries load tested and good to go. Now as long as nothing else decides to fail, I can finally get my tires replaced.
Old Dec 29, 2016 | 04:35 PM
WatsonR's Avatar
WatsonR
Good job... next time you'll be able to do the job in the parking lot, 15 minutes tops!
virgil spells
General Diesel Discussion
Sep 7, 2013 12:06 PM
medic25
Dec 10, 2012 02:20 PM
noel431
2004 - 2008 F150
Apr 18, 2010 02:35 PM
dieseldrivr
Jan 25, 2010 10:41 PM
hotrodmerc
Bronco II
Jun 2, 2008 11:13 PM
