2.7L leaking oil pan x3
#46
I have 2,000 miles on my 2017 2.7l. Is there any way to tell if I'm going to have an issue with it too? I called 2 dealers and gave them my VIN and all they said was to bring it in and leave it a day or 2 for them to look at. I haven't been able to do so. Its my daily driver and Ive got a long road trip planned!
#47
#49
CR, I would keep an eye on the oil level in your truck. The symptoms for me were rough idling and then when I accelerated hard I got the red warning box (with audible bells/dinging) saying I had low oil pressure. When I took it to the dealer, they said I had no oil left in the truck. Other symptoms include people reporting smoke from the exhaust. Goodluck!
#50
#51
#52
https://www.builtrightind.com/engine...engine-failure
#53
I would ask, once it arrives at the dealer, the will know for certain. Either way, you should be good to go. With the 2.7 being so new, I would expect it to be a new engine. Good luck.
PS: don't loose sleep over something you have no control over.
#54
#56
Why is ANY input you have negative?
#58
#59
Round 4 of pan replacement. The truck is at the dealer for warranty repair...again. They have ordered ELEVEN pans. That's 11. All are warped. Apparently there's a manufacturing problem. How can they be leaving the manufacturer as defective. Dealer said they are starting a hotline conversation with Ford about a solution.
#60
