Good evening, i have recently upgraded the factory sync system in my 2011 f350 lariat to a factory sync with NAV. I am looking for tha way to redirect the fideo feed to the rear view mirror to the nav system, i have found the wire coors and pin locations for the radio end, just need the info if there is a way to move it in the a pillar harness on the passenger side to the radi harness. did ford really put 2 different harnesses in the cab if you had nav or not?
any help would be much appreciated.
Factory nav unit and factory camera (camera was in the vehicle to begin with) thanks in advance
the radio side is pin 1 and 6 on the 10 pin radio harness.
Cobra Dave
You need a cable to pick up the video signal in the passenger kick panel area that can plug into the back of the radio. I ran into this problem also and was able to get one made. Check with 4Dtech to see if they have one or can make one. I think the guy who made mine is now part owner of this website.
The plug in the photos does NOT have the harness installed. Those 4 open pins will the the ones you use. Do not remember which the 3 pins are.
The camera will displace in the mirror and on the radio screen.
As a follow up, Thank You for the info and the location of the connector.
Here is what i did.
The wire color codes in the above pictured harness are V+ White/Green and V- Brown/Violet. if i had the pins i could have just added to the opposite side of the connector (i.e. the radio side of the harness) but it works great.
