I haven't done it yet, but I have read numerous accounts of guys doing it. The most common issue seems to be the ones below the radiator due to access or lack thereof. I'll try to post up some links...EDIT: I couldn't find any links for replacement of the insulators, but I would recommend reading some cab removal threads.
I just did this job a few months ago. What do you want to know? I don't have a write up on it or anything but I can answer any questions you have on how to do it! That second thread is the one I started on it
Dr. H, just wanted to get as much info as I could before I started. My wife bought me some energy poly mounts and was wanting see some pics of an install using the same mounts. I have a lot of info to start if I run into probs I will post up. Thanks for posting your experience, it's a huge help.
Is there anything special about the two mounts underneath the bed? Those are my worst two and likely responsible for the clunk I hear when I get the truck twisted.
How do you like the aftermarket mounts? IIRC, you went with Energy? Did you grease them as I've seen suggested in a few places?
edit: upon closer inspection none are under the bed. Duh!
Reason: Duh
Did you guys have a clunking noise under your feet which led to replacing your body mounts or just a rough ride?
I have a noise under my feet and the passenger's.
Ok that's really strange you mention this because over the past two weeks I have been chasing a weird clunk, grinding noise that I can actually feel on my feet when making turns at low speeds. I thought it was in the steering but everything is completely tight.
It feels like it's coming right from the body mount that's inches from your feet. But it hasn't always been there, I already have the new mounts but now I'm feeling/hearing this noise. I'm lost......
lol I was going to say there aren't any. Good catch
I am going to get someone to help rock my truck this week to see if I can pin point the noise. I took the sway bars off and felt sure they were the culprit, since that is where most of the threads with clunking end.
No dice.
I can force the noise just by hitting the gas or brake.
I just went out and had a look at the mount by my feet. Looks like I found my culprit. The mount is sliding and getting pinched, causing that grinding/popping noise. You can see part of it has actually been pinched off.
