7.3 no start
Old Dec 30, 2016 | 06:46 AM
BuddyBarnes's Avatar
BuddyBarnes
If you are sure you are getting power to the pcm then I would take the pcm out and try it in another truck . If you have another truck around.
Old Dec 30, 2016 | 11:22 AM
krifenbu's Avatar
krifenbu
First I would get a test light or a volt meter and open the fuse box under the hood. With key on, check for battery voltage on both sides of the top of fuse #22 with the fuse still in the box. Should be a 20 AMP according to the online manual. (oops on my truck it is 30 AMP).
Turn the key back off then pull the diode #12 under the hood. Turn the key back on and one pin should have battery voltage, the other one not.
If that checks good, then turn the key off and pull relay #1. See pic below.
On my truck, under relay #1 there is 12.xx volts on the pins at the 2 yellow arrows, and 5.xx volts on the pin at blue arrow. There was 0 volts on the other pin.
Turn the key back on and check for voltage on the pins under the relay.
If that checks ok, turn the key back off and swap relay #1 and relay #3 (horn relay) and see if that makes a difference.
If you have already done this then I am sorry to waste your time.
Did the WTS light work correctly before you did the work on the truck?
Kevin
Old Dec 30, 2016 | 01:33 PM
friskyjake's Avatar
friskyjake
Can someone list in order what each one of those relays go too? I don,t know what they feed. Thank you Friskyjake
Old Dec 30, 2016 | 01:47 PM
krifenbu's Avatar
krifenbu
I thought about posting this before, but I didn't.
Kevin
Old Dec 30, 2016 | 02:06 PM
krifenbu's Avatar
krifenbu
I forget that this is out there:
1996 Bronco/F-Series Workshop Manual
18: ELECTRICAL DISTRIBUTION
Section 18-01: Wiring and Circuit Protection
Power Distribution Box
Follow the one for:
F-Series Power Distribution Box, Diesel Engine Only
Lots of other good info there.
Yes I know it shows a pic of a 1997-2003 F-150.
Kevin
Old Oct 14, 2020 | 11:02 PM
Arkansas7.3l's Avatar
Arkansas7.3l
I just had a 97 that had some work done to it do the same thing. Started up and ran for about 20 to 30 seconds. Then died and wouldn't start back up.i ended up pulling the batteries to charge over night, pulled the fuel filter changed it drained the bowl poured in some fuel put in a fresh filter. Ended up checking the oil level to find it was a little low topped it off and cranked on it several times and it finally popped of very rough but cleared up after about 15 seconds.
ALC97
21
Mar 17, 2018 11:03 PM
finerant
Apr 16, 2015 12:17 PM
popeye4
Oct 19, 2014 09:10 PM
FirstTimeDiesel
Nov 16, 2011 12:25 PM
slomo1
Jul 10, 2011 02:04 PM
