08 E-150 Door Latch sticks
Old Dec 24, 2016 | 08:36 AM
BobRobi's Avatar
BobRobi
With the door panel off, if I push up on the vertical rod connecting the exterior door handle to the latch, the door will latch properly and also re-open (once only). The vertical rod seem to stick - not sure if the culprit is the handle or the latch. Any thoughts?
Old Dec 25, 2016 | 05:43 PM
Wildman25's Avatar
Wildman25
Is this manual door locks or power door locks?
Sounds like the exterior handle is sticking, like in the "open" position.
Try getting some PB Blaster in the exterior handle hinge, and if you can, inside the door, where the cam is attached with a screw to the handle.
The spring on the cam could also be broken off, not allowing the cam/rod to lift back up also?
If that's the case, replacing the exterior door handle is the best way to fix this.
Old Dec 25, 2016 | 05:57 PM
BobRobi's Avatar
BobRobi
Power Door Locks. Exterior handle appears to move freely. Spring on cam appears ok. Will try PB Blaster @ cam spring. Thanks!
bradlow
Aerostar
24
Jun 26, 2016 10:36 AM
hillcountryflt
Nov 30, 2014 12:33 PM
hunter301
Nov 9, 2013 09:02 PM
Charles Wulf
Dec 13, 2010 10:42 PM
Chuckwagon101
13
Sep 19, 2007 08:01 PM
