Block Heater plug mount
Old Dec 23, 2016 | 05:12 PM
cangim's Avatar
cangim
I put a marinco plug in the bumper of my last truck, and wanted something similar. I frequently have something in my hand and loved being able to plug in and unplug with one hand. Found a few images all on the passenger side where the plug is. Being lazy I nose right up to the garage so I typically do not have to scrape windows I wanted it on the driver. This is the location I chose
Old Dec 23, 2016 | 05:22 PM
Just Strokin's Avatar
Just Strokin
Nice upgrade. Do you have the part number, price and where you bought it so someone else might can do the same?
Old Dec 23, 2016 | 08:14 PM
cangim's Avatar
cangim
Amazon - currently $26.35
https://www.amazon.com/ParkPower-Mar...Marinco+150bbi
I found an older 14/3 extension cord, cut the molded end off with about 3' length, stuffed it in wire loom and ran a bead of silicone around the socket end then plugged them together; the cut end was stripped and connected to the power inlet. My preference would have been one less connection but the wire isn't that long, thought about heat shrink butt connectors, may still do it but the cold sucked the ambition out. If you are on passenger side fog light, there is enough length it will be slick, I just rarely am on that side. You'll need a 1 7/8" hole saw for this plug. Also, there is a small hole to drain water out of the plug, be sure that is down.
Old Dec 23, 2016 | 11:37 PM
HRTKD's Avatar
HRTKD
Mike, that's a pretty slick modification.
Old Jun 28, 2017 | 08:52 PM
Z22ZINFS's Avatar
Z22ZINFS
Marinco Block Heater Mod
1 7/8" hole
Test Fit
Finished look, with wood screws installed. They are SS.
I installed my Marinco in the ABS plastic housing around my 2016 fog light (Driver’s side). My method will work whether you have lights or not, since there is still an ABS plastic housing at the same location on the bumper of XL and XLTs. It looks GREAT! I ran into no problems with clearance. I thought I would need to put additional support to prevent from breaking the ABS plastic when plugging/unplugging. However, there is MORE than sufficient room for me to reach my hand through the opening in the front bumper and support the ABS while plugging/unplugging a cord. Instead of cutting and splicing the original cord, I bought an extension cord and cut it to length. I used Oxy-guard on the prongs, plugged the female end of the extension cord into the block heater cord, then electrical taped the two to keep water and dirt out. The Marinco connector was water tight around my round cut-to-length extension cord I put into the fixture. I'd recommend this mod to even the least experienced worker. I did not have to buy a 1 7/8" hole cutter because I had one in stock. I recommend a hole cutter, NOT a spade bit! The masking tape in the first photos was only to help me line up the optimum mounting location and location for pilot holes. (It would be hard to see black ink marker on black plastic.) I mounted mine a little closer to the curve in the plastic than the post by cangim. I wanted maximum strength plastic strength and the plastic part is strongest near curves. I used the three wood screws that came with the Marinco, making a 1/16” pilot hole first. The screws have to go on after the Marinco locking nut, or you won’t be able to tighten the nut.
Old Jun 29, 2017 | 07:36 PM
Z22ZINFS's Avatar
Z22ZINFS
The Marico part number is 150BBI. http://www.marinco.com/en/150bbi
Old Jun 30, 2017 | 10:15 PM
cangim's Avatar
cangim
Looks good, I have really liked it on the drivers side. Course it will be a while prior to use again for me
Old Aug 8, 2017 | 06:42 PM
mxer0022's Avatar
mxer0022
where did you find this 1 7/8" hole saw? I can only find 1 3/4" and 2".
Old Aug 8, 2017 | 08:30 PM
cangim's Avatar
cangim
With most things I get. Found on amazon, already had a few other sizes
Milwaukee 49-56-0112 1-7/8-Inch Ice Hardened Hole Saw
Amazon Amazon
Old Aug 8, 2017 | 10:10 PM
mxer0022's Avatar
mxer0022
I was hoping to find it in a hardware store so I didn't have to wait but I guess I will wait. Thanks for the link buddy.
Old Aug 8, 2017 | 10:11 PM
cangim's Avatar
cangim
I hoped the same, just no one had 1 7/8"
Old Aug 8, 2017 | 10:38 PM
Z22ZINFS's Avatar
Z22ZINFS
Actually I was fortunate to have one in stock from a previous job. But I think I originally bought it at my local Blain's Farm & Fleet. They carry DeWalt sized in 1/8" increments up to some size, then 1/4" after that.
Old Aug 9, 2017 | 09:13 AM
camminich's Avatar
camminich
How did you get the existing plug to reach the driver's side? Currently my plug is behind my from plate, I do not think it would reach.
*** Oh sorry, I see in the post above that one person did add a 3' section to make it reach.**
Old Aug 9, 2017 | 05:12 PM
Z22ZINFS's Avatar
Z22ZINFS
Also, in case you did not notice this in my original post, here is what I wrote, "Instead of cutting and splicing the original cord, I bought an extension cord and cut it to length. I used Oxy-guard on the prongs, plugged the female end of the extension cord into the block heater cord, then electrical taped the two to keep water and dirt out. The Marinco connector was water tight around my round cut-to-length extension cord I put into the fixture."
Old Aug 9, 2017 | 10:56 PM
camminich's Avatar
camminich
Thank you much for the clarification. Was there any reason you didn't put the plug on the passenger side, or was it just personal preference? I was looking under the bumper today, and it appears you could do either side for the mounting of plug. I may just opt to do the pass side since it wouldn't make a difference for me connecting to the power source.
Thanx
