new user
Old Dec 23, 2016 | 03:15 PM
mxsteve22's Avatar
mxsteve22
new user
Hi I have a 05' 6.0 with about 130,000 every thing seems to work fine except when I get on it, It takes off but slow not like used to, and the turbo whisles. When I get over 1000 RPM and let off it sounds like a jake brake not real loud but like something is covering the exaust on and off thanks.
Old Dec 23, 2016 | 04:25 PM
69cj's Avatar
69cj
You need more info than that. Boost for one and did you check the cac's and boots for leaks? Could also be a sticking turbo or vgt solenoid. That would require some live data.
Old Dec 24, 2016 | 11:29 AM
mxsteve22's Avatar
mxsteve22
I'm just am retired farm boy and don't know mutch where are these cac's and boots. I don't have a scanner that works on the truck. the boost goes to about 10
Old Dec 24, 2016 | 11:47 AM
69cj's Avatar
69cj
Max boost floored should be in the 25 to 28 psi range. The cac boots are the rubber hoses connecting the turbo to the intercooler and intake. It's not uncommon for one to come off or tear. Doesn't take much for one to lose boost. That's the first and cheapest place to start.
Old Dec 24, 2016 | 12:30 PM
BLADE35's Avatar
BLADE35
05 also had the plastic cold side CAC tube that tends to split thus the Duct tape mod for Temp fix if it leaks
Find the turbo and follow the 3" tubes there is 4 boots
1 at turbo
2 at intercooler by radiator
1 at the intake where it 90* into the intake manafold
Old Dec 27, 2016 | 02:48 PM
mxsteve22's Avatar
mxsteve22
I checked all of that and only found a loose clamp, but now the boost goes to 20+ and the black smoke roles. I still have the jake brake sound when I let off even at 1000 RPM. when I floor it I don't seem to have the power. I want to thank you for answering and wish you all a happy new year.
Chief Many Inches
20
May 6, 2017 09:49 PM
klaw
May 20, 2013 11:12 PM
blackpatch
Dec 25, 2009 09:00 PM
DieselRunner
May 16, 2008 07:37 PM
1978fordf250
16
Jun 25, 2006 06:01 AM
