New Battery
Old Dec 22, 2016 | 05:14 PM
bigdaddyII's Avatar
bigdaddyII
New Battery
Had a cold snap in the Deep South a few days ago. One morning I auto started the truck and noticed it cranked funny. Not like a weak battery, slow crank, but more like it took longer then usual to crank....enough for me to notice. It cranked normal after that, of course it warmed up as well, so I didn't pay much attention. Had the truck in to the dealer for an oil change and they tested the battery and it was showing around 500 cranking amps. I went and looked, as the eye was green. Had them use another tester and it showed the same. Oh well, $134 for a new BXT-65-750 to assure that next time the temp dips I can get started isn't too bad I guess. I'd always heard that Motorcraft batteries are tough to beat but only 2 years on a factory battery doesn't sound great to me. I also pulled the blanket off when I reinstalled the new one, I have a suspicion that it holds heat, which is plentiful around here.
On a sode note they wanted $30 to install a new battery. I paid for my oil change, walked to the parking lot, pulled the old battery and brought it in to buy the new one. Whole process took 5 minutes to get back on the road. Easiest $30 I've ever saved.
Old Dec 22, 2016 | 05:22 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I'm still on my factory 2011 battery and it's seen temps to -20F and never been extra slow to crank or anything.
I know heat kills them more then anything, which is something you guys in the south get a lot of.
Old Dec 22, 2016 | 10:00 PM
cb_13's Avatar
cb_13
The blanket is actually there to insulate the battery from the heat of the engine. Whether it works or not I don't know but that is what it's suppose to do.
Old Dec 23, 2016 | 05:05 AM
hammer65's Avatar
hammer65
I remember reading something, about having to do a computer update, so the computer knows you have a new battery. Can't remember the reason exactly.
this may be where the $30.00 came in.
Old Dec 23, 2016 | 05:48 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
I don't think the dealer did that to mine, I watched the tech pull out the old battery and install the new one and back it out of the bay. I could be wrong.
Old Dec 23, 2016 | 06:23 AM
hammer65's Avatar
hammer65
This might help.
Replacing a battery - the new way - Ford F150 Forum - Community of Ford Truck Fans
Old Dec 23, 2016 | 07:01 AM
bigdaddyII's Avatar
bigdaddyII
I'm aware of the BMS, and the truck as sat and completed the 8 hour turn around since I've gotten it home yesterday afternoon. Still not worth the $30 to me.
I'm thinking that blanket is suspect. My brother has a similar 2 year life span on his truck that had the blanket. This is absurd to me, and he didn't replace with Motorcraft batteries so I don't think it's the brand in particular. The blanket was removed on his with the most recent replacement. That was only a couple months ago though so we will have to wait and see.
Old Dec 23, 2016 | 07:56 AM
ubereal2's Avatar
ubereal2
The battery in my 2011 lasted 3 years, and quit one warm spring day, makes perfect since.
Since I had a newer battery in the 2011 when it was totaled out after 5 trees falling on it this last summer, I put that battery in the 2013 we bought. Then the battery from the 2013 went into my 79' Ka'Bluey.
Old Dec 23, 2016 | 07:57 AM
ubereal2's Avatar
ubereal2
When I put the new battery in my 2011, and in the 2013, I just swapped them out, and took off, and haven't had any issues.
Old Dec 23, 2016 | 08:06 AM
bigdaddyII's Avatar
bigdaddyII
at some point the truck is going to sit 8 hours interrupted, so I wasn't real worried about it.
Old Dec 23, 2016 | 08:44 AM
Robbgt's Avatar
Robbgt
I did not know about the 8hr idle time after battery replacement. Thanks for posting.
seventyseven250
2009 - 2014 F150
16
Jan 5, 2018 09:15 PM
jfsully
Electrical Systems/Wiring
Feb 19, 2006 10:40 PM
lotic
Dec 18, 2005 10:56 AM
ryn6609
General Automotive Discussion
28
Sep 9, 2005 03:45 PM
aurgathor
Jan 29, 2005 12:50 PM
