Need help with proper name of hose
I am trying to figure out what the hose in the first picture is called so I know what to ask for at the dealership. It is on a 1996 Bronco, 5.8 EFI. The hose is attached the the front of the intake on one end just below the throttle body then connects to a metal tube that goes to the valve in picture 2. Sorry the pictures are rotated 90 degrees.
That is the Vapor Management Valve (VMV). It's a newer version of the Canister Purge (CANP) solenoid used on the 1995 and older trucks. It opens to allow the gas vapors from the tank to be burned in the combustion process. The hose itself is nothing fancy. You should able to use a fuel rated hose from a parts store.
dlogan3762
24
11-03-2016 07:38 PM
LARIAT 85
05-08-2006 05:03 PM
mtbiker
09-17-2003 07:32 PM
