Squeaky belt
Old Dec 22, 2016 | 12:59 PM
kyle j's Avatar
kyle j
Originally Posted by knottyrope
its a splined shaft in the pic above, might just come off easy or not
Hope so it's cold as ***** out gonna try to get it done in the driveway
Old Dec 22, 2016 | 01:00 PM
knottyrope's Avatar
knottyrope
40 at the cape now?
Old Dec 22, 2016 | 01:01 PM
kyle j's Avatar
kyle j
Yea around 38 and raining
Old Dec 22, 2016 | 03:08 PM
kyle j's Avatar
kyle j
Already becoming a pain in the *** lol help greatly appreciated so went to go remove the little 8mm center bolt and it just spins so I turned Ac on then shut truck off and same thing? How do you get it out?
Old Dec 22, 2016 | 03:10 PM
knottyrope's Avatar
knottyrope
turn key to on with AC on, then go take bolt off
Old Dec 22, 2016 | 03:18 PM
kyle j's Avatar
kyle j
Truck off but key in the on position?
Old Dec 22, 2016 | 03:23 PM
kyle j's Avatar
kyle j
Still spins free with truck key in the on position and Ac on
Old Dec 22, 2016 | 03:26 PM
97-psd's Avatar
97-psd
Yes........
Old Dec 22, 2016 | 03:50 PM
kyle j's Avatar
kyle j
Originally Posted by 97-psd
Yes........
Maybe im confused what do you mean yes? If it spins free how can you get the bolt out?
Old Dec 22, 2016 | 03:53 PM
knottyrope's Avatar
knottyrope
I hope the belt is still on so it will lock up by the clutch
Old Dec 22, 2016 | 04:06 PM
kyle j's Avatar
kyle j
Belt on Ac turned on truck off, Ac never blew cold since I bought the truck could the compressor itself be junk or not enough pressure in the system to engage clutch? Am I better off returning the rebuild kit and buy a complete compressor?
Old Dec 22, 2016 | 04:13 PM
knottyrope's Avatar
knottyrope
should be able to put something in there to pry against it
yes no pressure will not allow clutch to engage on some systems
You should find out if there is a leak before going through the trouble of replacing the whole compressor. Don't want to kill the new one.
Old Dec 22, 2016 | 04:16 PM
  #28
kyle j's Avatar
kyle j
true ill see if I can pry or hold it somhow maybe a big oil filter wrench
Old Dec 22, 2016 | 04:18 PM
  #29
knottyrope's Avatar
knottyrope
oil filter wrench or a strap wrench is very handy to have
Old Dec 22, 2016 | 04:26 PM
  #30
oldbird1965's Avatar
oldbird1965
This was mine, there are no compressed parts that I remember.
