Heater can't keep windshield from icing up.....
Old Dec 19, 2016 | 08:15 PM
jake00's Avatar
jake00
Anyone else have this issue?
It was about 5 degrees out, Hit some sleet like crap. The windshield would ice over starting at the top if going faster than 30mph. (Was going 60-70)
I'd have to stop every 20 miles or so and scrape a thick layer of ice off, then it was start again almost instantly.
The defrost was on hi, and hot (this started happening 200 miles into a 350 mile trip).
It didn't help that the washer fluid wasn't coming out...
Old Dec 19, 2016 | 10:00 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Ive had the same problem with the large windshield on my 05 excursion 6.0 The only thing that helped was rain-x
Old Dec 19, 2016 | 10:04 PM
scott91370's Avatar
scott91370
It helps a little (maybe enough) to lower your sun visor. Keeps heat up at the top a little better.
Old Dec 19, 2016 | 10:56 PM
seventyseven250's Avatar
seventyseven250
If ice is falling from the sky, there isn't a heater in the world that can keep up. The newer "quietglass" windshields are even worse, because they are thicker.
Old Dec 20, 2016 | 10:34 AM
pikapp's Avatar
pikapp
Try the washer fluid spray to clear the ice. I do that in the mornings when the windshield is frosted over, cleans it right up, along with the defroster.
Old Dec 20, 2016 | 10:38 AM
rmccbride's Avatar
rmccbride
He will have to drill out the check valve first to get them working in below freezing temperatures... He was. Lucky he was able to get The door open to even get in the truck..
Remember all winter testing. Was done in Florida on these trucks..
Old Dec 20, 2016 | 10:50 AM
j.grif's Avatar
j.grif
You owe me a keyboard!
Old Dec 20, 2016 | 03:47 PM
sky Cowboy's Avatar
sky Cowboy
They had no choice but to....the testers complained Canada was too cold to work...
dustyroad
Feb 5, 2015 02:44 PM
forager
27
Aug 6, 2014 04:36 PM
stewart460
15
Dec 5, 2008 05:35 PM
Gary Hines
Oct 8, 2008 10:08 PM
Will_01_GT
1978 - 1996 Big Bronco
Oct 3, 2003 12:51 PM
