General Diesel Discussion
Brake Light Fuse
Old Dec 19, 2016 | 04:12 PM
Anna Carlton's Avatar
Anna Carlton
Brake Light Fuse
I have an 89 F350 7.3L dually 2wd.
Borrowed a trailer from a friend a while back, and ever since my 20A brake fuse blows randomly and I have no brake lights (running lights fine). I am replacing the fuse every week it seems. I'm thinking the trailer had a bad ground, the plug on the trailer looked damaged at the time but it was an emergency situation and I had to use it.
Anyone else experience a similar issue? Do I need to replace the entire harness? Thanks!
Old Dec 20, 2016 | 12:16 PM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE
if the trailer is not still connected that would not do it, unless the plug on the trailer was messed up and bent the pins in the trailer plug on the back of your truck shorting them out.
what i would do is disconnect the trailer plug on the back of the truck and see if it stops blowing fuses.
Old Dec 20, 2016 | 01:04 PM
lee00's Avatar
lee00
I was going to say it sounds like a chaffed wire inadvertently grounding out to the frame or body somewhere...
Old Dec 20, 2016 | 02:07 PM
tjc transport
i ain't rite
that very well could be to too Lee.
i like to start where the problem seemed to start and then work my way back to where there is no problem anymore.
disconnect trailer plug. if it stops that was the problem. if it is still there, disconnect at firewall plug. then at brake switch. sooner or later you will find a good spot and then can narrow down the area to investigate.
turboboost
Oct 11, 2009 12:45 AM
deereeeford
Electrical Systems/Wiring
Jan 3, 2008 02:50 PM
72soa
Oct 23, 2007 04:23 PM
97squarebody
Jul 8, 2007 07:51 PM
wat704
1997 - 2003 F150
Feb 28, 2005 10:57 PM
