Ignition Module Recomendations
Old Dec 19, 2016 | 02:53 PM
scottness2's Avatar
scottness2
Well my 1979 F-100 (inline 6) finally would not start. A quick tour on this site and some basic tests and it appears the brain box is dead.
I know what ignition module I need but was looking for recommendations on what brand to buy (or to stay away from). I figured someone has seen the good, the bad and the ugly and can save me the lesson.
Any help would be appreciated.
Thanks in advance.
Scott
Old Dec 19, 2016 | 03:07 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Ford Motorcraft yes...chinee cheap part no. If you can get one good one..get 2. Glove box spare. Hang on there will be some Ford part guru's chiming in with all the locations and ph#'s for you.
Old Dec 19, 2016 | 03:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Module is identified by a colored plastic square, above where the wires feed out.
What color is yours?
1979 could have a blue or red or yellow or brown plastic square.
Also, be aware that the stator (aka magnetic pickup coil) inside the dizzy could be bad, as the symptoms are the same as a failing DuraSpark module.
Old Dec 19, 2016 | 04:21 PM
okiewelder's Avatar
okiewelder
Module
My 77 f350 l have a spare already bolded under the hood so when it goes l can just unplug and plug and go!!
Old Dec 20, 2016 | 04:06 AM
Ozzie H.'s Avatar
Ozzie H.
As mentioned, domestic is usually better than imports. Motorcraft is good.
Always carry a spare. They are temperature sensitive. Try to keep them as cool as possible. If you do an aftermarket, you could try O'Reilly. They had a lifetime warranty in the past.
Old Dec 20, 2016 | 06:33 AM
Dave145's Avatar
Dave145
As stated, motorcraft is and always will be best. That being said, the only other brand I've found that hold out is O'Reilly's house brand MasterPro. I've tried the BWD boxes from Advance Auto Parts, the Standard brand boxes from Napa, the El Cheapo no namers from Rock auto and other sources....Long story short they all died within roughly a month or two. My old '78 I no longer have burned through those things all day long even though the whole ignition system was new with good factory components. My current '77 has gone through two, but the MasterPro seems to be holding out for now.
Pryan68
Jul 16, 2016 03:43 PM
four-sixty-power
Jun 30, 2015 04:52 AM
74 F350 SCS
Sep 12, 2012 09:34 PM
berry1234
Aug 23, 2010 01:10 PM
tractoman
15
Jan 2, 2008 02:45 AM
