Sponsored by: Real Truck
Rim compatibility
Old Dec 19, 2016 | 08:19 AM
Fasteddy83's Avatar
Fasteddy83
Rim compatibility
hey guys I just picked up a 04 f250 with low kms (135,000) at auction and I founds some stock ford black steel rims off a 2014 f250 will they fit on my truck ? , I just want compatible and no pissing around with spacers etc. Thanks in advance fellas
Old Dec 19, 2016 | 10:08 AM
Sam I Am's Avatar
Sam I Am
Any stock SD wheel 2005 and later will require "pissing around with spacers etc." as you put it due to the change in offset & brakes in model year 2005.
Old Dec 19, 2016 | 10:12 AM
Mike189677's Avatar
Mike189677
They will bolt up but the offset is different and will be tucked up under the truck. This is why people use the spacers with the newer wheels on the older trucks. My opinion is pass especially if you don't want to use spacers and you would also need a hub centric spacer not lug centric. There are super duty wheels all over the place finding some that will fit won't be too hard.
Old Dec 19, 2016 | 10:15 AM
Fasteddy83's Avatar
Fasteddy83
Exactly what I was thinking, thanks again guys
Old Dec 19, 2016 | 11:53 AM
Brad Brown's Avatar
Brad Brown
I have a 1974 F250 with 16" tires and was wondering the same thing? will those wheels fit on a 2010 F250 Super duty? I would think so????
Old Dec 19, 2016 | 12:01 PM
Sam I Am's Avatar
Sam I Am
Different bolt pattern, Super Duty is 8 X 170mm, old one is 8 X 6.5".
Old Dec 19, 2016 | 12:45 PM
Brad Brown's Avatar
Brad Brown
Well that is a bummer! Close but no cigar eh??? 6.69 " instead of 6.5"
dam metric **** anywho!
Nov 26, 2015 07:14 PM
Paso1
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Aug 31, 2014 09:33 PM
craypc
Apr 21, 2013 09:26 PM
Dustball8504
Jun 13, 2007 12:12 PM
quick01lightning
May 19, 2006 05:50 PM
