2005 wheels on 2000?
Old May 18, 2006 | 05:49 PM
quick01lightning's Avatar
quick01lightning
is there any difference on the stock f250 rims on 2005 verses the older?(ive got a 2000)i found a guy about 2 hours away who is selling his stock 17" rims with tires for a really good deal.ive gotten conflicting answers.some say they are the same some say diff. pattern and others say i will need spacers because of the offset difference if so where do i buy the spacers.thanks for any help
Old May 18, 2006 | 06:00 PM
turbostroke's Avatar
turbostroke
The bolt pattern is the same 8 on 170mm BUT the wheel offset itself is different therefore making the inside of the rim hit the brake calibers. 8 lug spacers may be difficult to find and even if you do you are probably in the same price range as if you just purchased some new rims that fit correctly.
Old May 19, 2006 | 12:15 AM
jtharvey's Avatar
jtharvey
You would need spacers, and I personally wouldn't want to run spacers on a truck as big and heavy as the Super Duty.
Old May 19, 2006 | 12:46 AM
quick01lightning
i just got a email from the guy and he parted out the tires so forget it.thanks for the input thou.dam i like the look of those 17" rims
Old May 19, 2006 | 06:43 AM
tjbeggs's Avatar
tjbeggs
i will let you all know what we find. a friend of my dad and I just gave a 17 to try on my dads 03. so we will see what happens
Old May 19, 2006 | 09:52 AM
quick01lightning
cool let me know what happens.i guess the problem is the offset so they rub on the brakes.if not maybe ill buy this guys rims and just put on new shoes.thanks
Old May 19, 2006 | 10:43 AM
SpringerPop's Avatar
SpringerPop
Be aware that the difference in rim offset may result in additional stresses being placed on your wheel bearings. If you have a 4WD, they are sealed, and only replacable as an expensive assembly.
Pop
Old May 19, 2006 | 05:50 PM
tjbeggs's Avatar
tjbeggs
well the wheels we tried were 18's and would work but the tire would rub pretty hard on the spring. the offset brings the tire into the wheel well more and thus the rub. so my dad is looking at harley 18's cause they will fit cause the offset is right for the 03
Ekkehard
2004 - 2008 F150
Oct 12, 2012 10:10 PM
bimmertrek
Oct 26, 2011 01:48 AM
Gental Ben 2
Jun 13, 2010 06:28 PM
ttrunkle96
New Member Introductions
Dec 6, 2007 05:30 PM
