brake controller question
Old Dec 18, 2016 | 12:46 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Where were the brake controllers plumbed into originally? front MC port or rear port? Mine is now on the rear port, but I was wondering since the front port would move more fluid, or does it even matter? Thanks.
Old Dec 18, 2016 | 01:00 PM
tbear853's Avatar
tbear853
When I had one, I tapped into the rear brakes which was the most forward port. Adjustment for actual application was inside the carb.
Old Dec 18, 2016 | 06:46 PM
Blue and White's Avatar
Blue and White
My truck was set up with a brake line pressure controller and I removed it. I figured the electronics were questionable after that many years. Also, all new setups I have seen are electronic. There must be a reason.
I now have an all electronic controller with no brake line tap.
Old Dec 18, 2016 | 08:07 PM
BigSexy78's Avatar
BigSexy78
I would recommend getting a new brake controller. They are electronic and alot easier to install. No messing with your brakelines. I have installed them for over 20 years. You will not regret it.
Old Dec 18, 2016 | 08:38 PM
F-250 WARHORSE
The electronic ones came about because of antilock brakes. No way to put a hyd. unit in with antilock. I have had a lot of electronics, they service me ok. I prefer the hydraulics, the more brake I apply, the more trailer brake I have. The electronics are determined by a pendulum, swinging back and forth, and as you stomp the pedal, the pendulum is thrown forward, increasing brake power. I hope you aren't on a slick road and need to stop from rolling down the hill, backward, or hope you aren't backing a boat into the water on a steep wet ramp. The pendulum thinks it is not trying to stop and won't actuate unless you manually do it. Thanks for the help I have mine t-d into the rear brake port, as all others I have ever seen.
Old Dec 18, 2016 | 08:55 PM
PA74F250's Avatar
PA74F250
New controllers don't use a pendulum. I think the last one I bought several years ago was a Tekonsha Primus IQ and it doesn't use a pendulum. I really like it and if I remember right it didn't matter how I mounted it unlike the old pendulum kind.
As for backing up it apply the brakes just as the same as going forward unless I tell it not brake which I usually do.
Old Dec 18, 2016 | 09:14 PM
BigSexy78's Avatar
BigSexy78
Get you a Redline TA1000. Very good dependable controller at a good price, usually around 65 dollars. It is not a "pendulum style" as mentioned. It will turn on your trailer brakes anytime at the power you have it set at. There are also a number of digital controllers out there also that are good if you like to see a number instead of a colored light.
Old Dec 18, 2016 | 09:22 PM
PA74F250's Avatar
PA74F250
Mine is the digital kind and around $100 if I recall.
Old Dec 19, 2016 | 07:03 AM
F-250 WARHORSE
I have always had pretty good luckwith the old hydraulics, They work fine. They are dependable and simple, rugged and consistent. Thanks for the help.
Old Dec 19, 2016 | 10:40 AM
okiewelder's Avatar
okiewelder
Controller
I worked at a truck shop in OKC 20 years ago. We intalled the hyd ones and then switched over to the electronic ones. So much easier to install and never had a complaint and l have used a few over the years and they always worked the way they were supposed to.
49 Ford F-1
Mar 26, 2019 07:52 PM
Piffery1
Feb 25, 2010 07:16 AM
bama210
Modular V10 (6.8l)
19
Mar 13, 2009 10:58 AM
Sycostang67
All Things Towing
Mar 21, 2005 04:04 PM
