Bad backup camera
Old Dec 16, 2016 | 08:27 PM
cullenkyla's Avatar
cullenkyla
Bad backup camera
2015 KR supercrew 360 camera at first just different colored vertical lines. then it would start working again. Now it like it takes a picture when you put it in reverse and that is it. But most of the time its just lines. Has been in the shop at least 8 times putting on different parts. Now it will not work at all Now Ford is saying that all the camera's have to be lined for it to work and that is a special tool. Just feel that I'm getting the run around. Has anyone had this problem and was there a fix?
Old Dec 16, 2016 | 08:46 PM
brokenleg's Avatar
brokenleg
Id make sure I get everything on paper. then if they cant fix it, lemon it
Old Dec 16, 2016 | 08:51 PM
cullenkyla's Avatar
cullenkyla
They have not given me anything on it at this point
Old Dec 17, 2016 | 08:37 AM
Lost_in_tx's Avatar
Lost_in_tx
I had some work done recently and it came back with the scratchy lines you're talking about. They unplugged the power source/plug for the camera at the bottom of the bed and found there was moisture inside the plug itself. A quick blast of air and heat and problem solved.
Old Dec 17, 2016 | 10:18 AM
GlueGuy's Avatar
GlueGuy
If water got in there once, it will get in there again. I would suggest you put in some hydro-phobic gel inside the connector, such as DC4 or similar.
rbsev
Aug 21, 2017 05:58 AM
fordf2501
Oct 23, 2016 10:23 AM
portsample
May 21, 2016 07:02 PM
jg96powerstroker
Oct 20, 2011 07:36 PM
Ripbc
Jul 11, 2005 07:04 PM
