Mid-ship "Clack" at startup..
Old Dec 16, 2016 | 06:51 PM
wiskeyVI's Avatar
wiskeyVI
Good Evening.
It's been a bit brisk here the last couple days.
Two mornings ago, when I started the van for warm up, there was a loud "CLACK" sound that seemed to come from underneath the middle of the van.
It's happens almost every startup since.
Sometimes it right at strat-up, and sometimes its a second or two after it fires up.
It sounds like a metal valve being put under pressure or closing with vacuum..
Any ideas out there as to what it might be? I know what I'm hoping its not!
Thanks
Old Dec 17, 2016 | 08:54 AM
gman97005's Avatar
gman97005
Cracked Flexplate ?
Old Dec 17, 2016 | 09:32 AM
wiskeyVI's Avatar
wiskeyVI
I don't think so. I'm thinking maybe the fuel pump for some reason.
Old Dec 17, 2016 | 12:48 PM
Wildman25's Avatar
Wildman25
My '05 E350 SD has a similar noise that your describing, I'm thinking it's coming from the ABS unit, "clicks" real loud right after the dash check lights turn off.
Is your ABS light on after start up/run?
Old Dec 18, 2016 | 05:38 PM
wiskeyVI's Avatar
wiskeyVI
No, the ABS light hasn't come on.
I did install a new set of rear tires last week...
violator4200
15
May 25, 2020 05:59 AM
Ed in Maine
Sep 16, 2017 10:14 AM
Bad Bad Leroy Brown
May 30, 2013 08:28 PM
brt
Aug 18, 2001 06:31 PM
