Sponsored by: Auxito
more codes
Old Nov 19, 2007 | 05:24 AM
homer1972's Avatar
homer1972
more codes
Has anyone heard or ran into getting misfire codes on different cylinders after changing plugs and putting on a new coil. I was wondering, since after I replaced #4 coil, got misfire code #8, replaced that one have misfire #1. I have seen simiular results with a GM 6.2 glowplug, where 1 goes bad, others die slowly. I'm to the point of changing other 6 coils. It's on a 98 F150 4x4 5.4 auto w/168k. I talked to a dealer, and they said they have seen it before. Any ideas?
Old Nov 19, 2007 | 06:12 AM
projectSHO89's Avatar
projectSHO89
What brand of plugs did you install?
Steve
Old Nov 20, 2007 | 05:21 AM
homer1972's Avatar
homer1972
I had a local garage do it, I believe they are Autolite Platinum (he does alot of business with a local NAPA). Dealer said it may cause it and maybe should have used Motorcraft. Now truck is running good, got a another coil to put on #1 as I get a little "hiccup" now and then but no codes. Thanks for the reply!
Steve
Old Nov 20, 2007 | 06:03 AM
projectSHO89
The AutoLites should be fine.
Might be just time for your COPS to give out.
Steve
Old Nov 21, 2007 | 02:57 AM
LxMan1's Avatar
LxMan1
Yeah, they are all about the same age and it seems that when one goes, others often follow.
Old Nov 21, 2007 | 09:37 PM
homer1972's Avatar
homer1972
Replaced the #1 COP today, but wouldn't you know, it wasn't completed tightened down....Figured since I took it off and had new part, might as well replace it. Thanks to all for the help
